Thanks, the front sub-plate is bolted to the chassis on the sides and onto the bottom, using aluminum angle pieces. The top bolts onto those angle pieces, also. The faceplate will have 4 visible bolt recesses. It bolts through the sub-plate and into the chassis. The fifth and sixth holes are for the LED's.Looks great Lance!!
How did you attach the front plate to the chassis with no fasteners
visable??
Things look to be coming along great, Lance!
RC
With the 100 ohm 3 watt blue panasonics, I had no choice but to go with the
"longer" holes.... What resistors did you use, or did you stand them up? I would have assumed the "shorter" hole would have worked, did you ask Peter about that?
I'll try to locate the post by Nelson about the feedback, I took notes during my read to try to simplify finding things during construction. I'll post pics of the stuffed boards.....
Russellc
Yessiree, the Amana blade is a treat to use, Denny, and you're absolutely right about the ease of the metalwork. Anyone that has decent measuring tools, a drill, and is in any way practical, should be able to build a fairly nice chassis.Looking good Lance! Everyone should know that metalwork like this isn't as hard as it looks. A lot of the stuff can be done with basic tools most everyone has around their house. And those metal blades are the hot ticket aren't they?! We have a couple skillsaw style saws at work. Amazing that you can cut through 1/4" plate steel like butter. They will cut through 1/2" or thicker if your patient.![]()
The standoff blocks are HDPE (high density polyethylene) that I had left over from making various slides and fences for woodworking tools. I followed Tal's lead on that and they worked out very well. The material is available at local woodworking stores like Rockler, Woodcraft, etc..Lance,
where did you source the white blocks that the pcb's are mounted on??
I can't speak for Lance but 'I' threaded mine..Lance,
Are the standoffs threaded into the HDPE or glued??
Nice work Lance. I actually smoked one of my R11/R12 pairs too.
Regarding the stand0ffs, I understand the desire to mount the boards on something, and I actually communicated with some of the other builders on diyaudio.com about this. Most don't mount to a solid base, mostly because the board is so light that it's not needed. Many also contested that having the boards solidly mounted could cause trouble with added stress on the pads of the pcb. I argued that if you mount to the standoffs, then soldered it shouldn't matter.
But bottom line, my boards hang by the TO-220's from the heatsink. I run mine multiple hours per day, ever day for several months now without issues.
I press-fit and glued the nylon posts into the blocks. I used a two-part epoxy to glue them to the chassis bottom.Lance,
Well done Lance!
Enjoy the music....
Thanks!Excellent!
That looks great! Now what about a face, Lance?? :scratch2:
Hey Russel,That's great westend, Icant wait to fire mine up. I'll remember to double check the pot settings before hand. I do have a variac, so that may ease the problem. Hook that beast up to some speaks!
Russellc
Thanks!
I've got some work to do on the faceplate. My current plan is machine an edge on face, finish process the six surfaces, see if I can get an "F5" graphic of some sort, and meet with the anodizer to see if he can apply a tint to meet my choices. I'll be firing up the router, this evening, to see what I can accomplish.
Hey Russel,
I used the "poor man's variac", the 100w bulb device. Unfortunately, it was the first time I used it so I didn't know how it would limit current. I did know that it would show if I had a short and since all was good and no shorts I proceeded to full power. Within a few seconds, I realized all was not good and I flipped the switch to save the components from damage.
I had measured the trimmers before installation (this is really the best way) but trying to measure the resistance value in circuit does not lead to accurate results. I was relying on past information so I turned the wiper fully counter-clockwise. That is wrong!The 5k Bourns pots are zero'd by turning clock-wise.
A variac, of course, is the best choice, and I have been looking for one for reasonable price. Heck, I have an Oscope that just arrived and haven't had time to put it through the paces. A man can't have enough tools is my motto.
I will, hopefully, have the F5 hooked up to listen, tonight. Will report back with results.
As to the pots, there is a difference in the Cviller and Daniels boards. they connect different legs together a little differently than each other, resulting in OPPOSITE results. One results in minimum reading counter clockwise, the other clockwise. There is a very recent post on the F-5 thread over on DIY.
Russellc
