westend
Audiopile
I do sse the light, Master! :yes:Well guys, I think he gets it. Well done Lance, we'll see you on the forums in a month or so when you are done with your first listening session.
btw, I have a T1 through my C-2x, and it is a very nice tuna. It does KBEM justice.
(Effusive thanks post will follow at the end of the build, lol)
I was about to edit the above post but I'l add it in here: Another heart-stopper, tonight and it is all about best practices vs. none.
I needed to make up some interconnects since the last incarnation of my main system was all ended in balanced cable and other interconnects have been parcelled out to different systems. Plus, I had wire, I had connectors, and I am totally compulsive.
After making up a couple of pairs I installed them into the gear, the first, Vampirewire twist-ons, the second Audioquest (some type of snake).
When I first fired everything up I didn't have any sound out of the right channel. I reached around to the back of the preamp to see if one had loosened and got a few bursts of sound. Oh no, I thought, something is terribly wrong with the amp or preamp. To see if the preamp connectors were loose, I pulled a little on the Audioquest connected wire and it came off in my hand.
Now I remembered that I had tested the first pair for continuity but, in my rush, had not tested the second pair. I looked at the connector and there was no solder on the positive terminal. Either I forgot to solder this one end or the base metal shed the solder. I'm thinking the latter. I've attached a couple of pics of the connectors and my advise is: test your work to prevent early coronary attack and don't buy Audioquest, get the Vampirewire.
I also took a couple of bad pics of the "Plant Hangers", the Fostex horns, since some folks might be at a loss as to what they are. Sorry about the mess in the shop-o- grunge, it's been a busy couple of weeks and the cleaning guy hasn't shown up.
) Tuner-Yamaha T-1, Tape deck-Nakamichi CR-3A, CD Player-Panasonic DVD recorder DMR ES-20, Speakers-DIY "Plant Hangers", a Fostex single driver back loaded horn.
