I was thinking just the same, somthing like this:
Nice photoshop pic.:thmbsp:
Now it looks balanced.
you can see it.I can't compare something I have yet to see or hear..
now that is just a silly, unsubstantiated blanket statement- utterly meaningless.Having said that, even if the technology was the same it would still be an improvement over the vintage.
A statement like that without any referencing or specifics is just an opinion. Some components have got better, some worse, others just aren't made anymore due to cost. Audio specific components are disappearing like wildfire.Capacitors, Transistors and the like have much improved in 30 years.
By all means disagree, but present something useful in your defence.So I would have to disagree with restorer-john for that fact alone.
OK, it most likely DOES have a microprocessor. It has a remote control for a start and that requires at least a microcontroller with its associated clock and noise and I will bet the speaker protection/overdrive uses the same main cpu as the remote as they always seem to do these days. You don't think Yamaha is going to scrap its RS remote ICs for this model do you? My bet is you will find a micro for the remote, speaker protection and input switching. You will probably also find a few ICs in the line stage too.As far a microprocessors, doesn't look like it. I'd also be concerned about it being discrete design and not a bunch of IC's everywhere.
Unlike some Tokyo by night designs which shall remain unnamed for propriety's sake, Yamaha has always been minimalistic in its design philosophy. Their successor to the MX-1000 namely the MX-1 has no LEDs, never bothered me a bit, I keep the LEDs on my MX-1000 off anyways. I am fully confident my NS-1000 speakers as well as Canton Ergo would easily handle the power. Yamaha's minimalism has always appealed to me. Even in their HT receivers or their pre amps like CX-1 where everything is hidden, they also did away with the loudness and tone control turn over, in the YPC-1, its even more minimal with a volume and balance, nothing else and it looks heavenly.
"A pioneer A91D or an SA9800 would eat it for breakfast as would a big 80s sony integrated. Yamaha's own integrateds from the 80s would also kill it performance wise."
John, a serious question... Would the 80's integrateds (or any 70's or 80's amp) still measure today as when new, generally speaking?
Thanks.
Well guys, go check the brochure out and decide. I love the specifications. the 120watt is achieved at 1kHz and the amazing distortion level of 10%! The 190 watts is the same at a mind blasting 10%. Phono deviation is equally as crap at 20-20 within 0.5dB WOW thats high end (not). S/N is an abysmal 98dB. Separation is 54dB at 10kHz on a line input- very ordinary for a 'balanced' design. She aint a DC amp and have look at those ICs for the line stages, the phono preamps. Caps are a standard nichicon fine gold. The whole thing is two core double insulated because they are scared earthing will upset the S/N even more. Bias and Offset pots are not even multiturn, so EW will be replacing them in a few years. Come on Yamaha, the phono EQ is not balanced and yet a phono cartridge is one of the true opportunities for a wholy balanced system and you wasted the opportunity and put in an ordinary RIAA stage! The caps pictured are 22,000uF caps, not 24,000uF unless they are adding another 2,000 for the voltage stage caps- likely. Honestly guys, there is nothing groundbreaking here- just a concept (the fully balanced NPN output stage) that has probably been on he shelf for 20+ years and this seemed as good reason as any to build a few.
The A-S2000 looks great without meters too.Unlike some Tokyo by night designs which shall remain unnamed for propriety's sake, Yamaha has always been minimalistic in its design philosophy. Their successor to the MX-1000 namely the MX-1 has no LEDs, never bothered me a bit, I keep the LEDs on my MX-1000 off anyways. I am fully confident my NS-1000 speakers as well as Canton Ergo would easily handle the power. Yamaha's minimalism has always appealed to me. Even in their HT receivers or their pre amps like CX-1 where everything is hidden, they also did away with the loudness and tone control turn over, in the YPC-1, its even more minimal with a volume and balance, nothing else and it looks heavenly.
