Here is my limited recollection of discussions with Marc Morin. He felt like that foam washer was not necessary at all. On any table he worked on he would completely clean and remove any residual foam at the top of the platter well. He would also clean out the platter well to make sure none of that hardened foam remained in the well. When reassembling he would not put any type of washer back in place. His perspective was that as long as you kept the well filled to the brim with a synthetic oil, it would float up any debris that might find its way under the platter and into the well.So I've been thinking about that felt /foam(?) washer that use to rest on the chassis under the sub-platter at the spindle.
As we all know over the years it disintegrates and if left in place crystallizes and needs to be removed.
I've been wondering if finding something to replace it might be worthwhile.
The M44 is the same as the M55, I believe. These have gone up in price since I bought mine but it’s a good one. Might be cheaper options I don’t know about.I´m getting a AR XB1, that currently has a Shure M44MG cartridge with a N44G stylus. Since that stylus seems not in production anymore, is a new cartridge the way to go, or find a NOS N44G. Opinions? Seller says it´s still good but on a downward slope.
I bought several cheaper styli for the 55 and none tracked at all. The VividLine was about $75 which was a great value. Now I’m not sure.
N-44G IMP NUDE
Manufacturer : SHURE NUDE Tip is used for this product: The entire tip of a NUDE Stylus is composed of diamond, as opposed to bonded tips. The tip angle and round shape are identical to those of a standard bonded tip, while the diameter size is similar in comparison to the SAS series. #N44G...www.jico-stylus.com
Nashou
That's a beauty!Is there any good alternatives to the Shure M44 cartridge? what does u guys run on yours?
Pic of the XB1 I´m getting (yes it is a auction, but good luck outbidding me)
N-44G IMP NUDE
And the best you can get for it.
Nashou![]()
N44-7 IMP SAS/B
The SAS cantilevers are fragile due to the materials that are used. The SAS products are manufactured for Listening/HIFI use and is not recommended by JICO to be used for DJ performance and play. Manufacturer : SHURE Super Analog Stylus (SAS) Profile Tip The tip of the is carefully chosen from...www.jico-stylus.com
Answer is right there ^^^^ many choices of styli for your M44, all those will fit.Is there any good alternatives to the Shure M44 cartridge? what does u guys run on yours?
Between @StuartB and I I think we can do what he is looking for or maybe advise as needed. I think I saw someone in FB saying they do AR refurbs. how about @sfrost?Regretfully, David does not do XA's or XB's anymore, though he stocks parts for them. @Hose53 , do you or would you know who can do XA refurbs?
Hi cmarti!Does anyone knows of anyone who restores AR XAs? I have one that needs a lot of help.
Thank you, I will do just that.Hi cmarti!
Reach out to @StuartB or I, see if we can help you out. Marc Morin, God rest his soul, worked with Stuart and I to pass on some of his upgrades to help him wrap up some project he still had on his table. We do what we can to carry on some of his work.
We can also supply some advice if you want to try and do some of the work yourself.
You might also try @sfrost, he does some really wonderful work.
Best of luck!
Is this cart worth getting a replacement stylus for? If yes, which one?
Try theIs this cart worth getting a replacement stylus for? If yes, which one?
| 4604-DEC |
Seems almost to cheap? Haha, nothing is $25 in this hobby.
