whoaru99
Epic Member
sounds like something that could have something to do with how "forceful" the sound is
Ripple current rating mostly about tolerance to ripple. It's not like there's a bigger dude in there pushing out the electrons harder.
They may test fine until a second before they let loose. Which is the problem. You never know when that will be.
but more ripple is more energy..... a tolerance to more energy is probably good for sound
Doesn't quite work that way. Ripple current is what a power supply capacitor has to deal with. The output of the rectifier is not clean happy DC voltage. Its a ripply wave form that looks like this:
Ripple current is the current that the capacitor has to supply in the periods when the output of the rectifier is low, and the current back into the cap to charge it on the peaks. The ripple current rating of the capacitor is just how much of that it can deal with. Its not any sort of energy rating, its simply a capability rating. Think of it like a weight rating on a shelf. Its not what the shelf weighs, its just what you can put on it before it fails. The "energy rating" is a combination of the capacitance value and the ESR value. More capacity = more stored energy. Lower ESR means it can deliver a higher amount of current. Thats not necessarily related to the ripple current rating, but it is related to how much dip and sag can be measured in an amplifier if you ask it to reproduce some high power impulse, say a bass drum hit. Its a big power sucker but for a short period. A high ESR capacitor cannot deliver as much current, so the power supply voltage sags more and you get less power output as a result.
The type of terminals on caps really doesn't have a lot to do with anything. The fact that things aren't available anymore isn't part of some conspiracy to keep "the good stuff" away from us plebes, its simply not in heavy demand anymore so manufacturers don't make it. Things are not commonly built with point to point wiring anymore, so caps that were wired up that way and mounted in clamps aren't really needed. Modern stuff solders the capacitor terminals to a circuit board because its easier to build it that way. You can't easily get bias ply tires or TV tubes tested at the drug store anymore either. Its not a conspiracy, there just isn't a demand.
I would suggest that if your gear sounds worse after being worked on, either the work wasn't done correctly or the wrong parts were used. There are modern caps that would be worse performing than the originals, but you'd have to look at the spec sheets to make sure you're using appropriate replacement parts.
the terminals on caps seem to increase in size in relation to size and ripple rating....
I mentioned this in another thread. The older caps have different specs than newer caps. I can't say for sure what the specs were in the old caps but the new caps have published specs. When you get to the larger caps, ±20% is common and with modern 6-sigma manufacturing techniques, the cap can be built at the low end of the range, say 10-15% below the value stamped on the cap. Back in the day, statistical process control was just getting underway with W. Edwards Deming's work at Sony in the 50s. I'm sure that the improvements were spread throughout Japan but how long it took to get to the capacitor manufacturers, I don't know so a new cap back then, maybe rated -10%/+70% may well have been built at the +20% level to achieve consistent 'on-grade' production. I'm not saying this is the way they were made, just throwing it into the discussion on caps.
This means that 10,000 cap would be measured at 8500-9000 for a new cap and measured at 12000 for an old cap when new. That is a big enough difference to be a possible cause of the lack of performance on the new caps. We may be putting in caps that were below what was used back then and calling it good.
Of course. If the capacitor is designed to be used where there is high ripple current then it has to be built to handle it.
There is a large plug with large terminals on the cord to an electric range or welder. There is a small plug with relatively small terminals on the table lamp. Why? Because they are designed with the expected current requirements in mind.
wouldnt a giant EL transformer appreciate a capacitors ability to make use of high ripple current? id imagine a giant EL would have higher ripple current than a toroidal
if the old 80v 6800uf rubycons were designed with significant headroom vs the newer nichicon kg's with tight tolerances, it makes sense as to why the rubycons seemed to hit harder
And you know this because?
One strange caution- the measured value of very old caps often rises. Those caps will give lower ripple than fresh ones of the "correct" value, that are usually near their lower tolerance. I still replace 'em, because they're on their way out!
It might do... (by the way it's "EI") but you haven't said anything about the size of the toroidal transformer you are comparing it with?
