I made a vain attempt to "improve" this TubeCube|7 that I have, and it made no difference. The cheap off-brand capacitors took a dump and the power supply wouldn't power it anymore until I recapped it. (Without fail, every cap I measured was right about at the lower limit of tolerances, and the one or two that were below the 20% tolerance probably prevented the switching power supply from working.) I made a couple of recommended capacitor substitutions while I had it open, but I still find it has a wicked rolloff past about 10kHz--it sounds like everything is under a blanket. It's a design flaw--another online review says the same thing. It's not bad for background listening but after a couple of years, I find I'm missing a lot.I wonder if a few capacitors were upgraded could it make a noticable sonic improvement. However subjective the evaluation of what's improvement. Would this be better area to try upgrades?
I don't know which capacitors are used in this Reisong amp, but I would not be opposed to putting a few dollars into maybe bumping the caps up to Nichicons, even if it only improves stability and reliability. Wired as it is, it should be a simple job and might actually be fun to tinker with.
