Open Baffle Epiphany!
Hello all-This is my first post here, I've enjoyed this thread very much. Thank you guys!....anyway, I decided to order a pair of wild burro's and built a baffle in similar dimensions to Caintuck audio. Wow is all I can say, this open baffle sound is for me. I love the tone. The grills I made are because I have a young family, pets too. They are removable, but I actually like them on....Associated equipment is a well tempered Amadeus>D-103>A-23 step up>Shindo Auriges>Vac pa 35/35. I use Belden and WE wire. I use and love Devore super 8, but this is a new sound that I love.
Welcome to AK! And congrats on your Betsy baffles!
Thanks Poultry.
Yes I meant 49CZ903. I'm really liking these things in my early days of playing with them!
RE the B and C versions of the tweeter, do they sound a lot different than the A version?
Also thinking I might try the Goldwood paper cone tweeter that Glow In The Dark Mentions.
The A is better but the others are still very good. I googled Goldwood paper cone tweeter and found the GT-25 which is 90 dbs. It would not be good match for the Zeniths which I estimate are in the high 90's. You need super tweeters that are 100+ dbs otherwise you won't be able to hear them.
Rolls SX45. The FR are not going thru active. Just running the FR straight on the SET45. It's a real possibility I have this wiring completely wrong. Using a passive pre amp. The forward most connections on each side go to the 45 amp. The rear connections have a Y. One to the phono pre, the other to the active crossover. From the crossover to the 2a3. Tried uploading a pic numerous times, gave up
You may have your connections wrong as the woofers played without the HF should not sound very good.
If you can make out any semblance of a tune then the woofers are playing the HF which should be filtered out completely.
I've been running my 4 small open baffle speakers now for a few months. I replaced some Polk TSi200s with these 8" vintage Heppner full range drivers mounted on small open baffles.
Yesterday, I decided to A/B the Polks vs. Heppner OBs using a Niles speaker switch again after listening to the OBs for a couple of months. I was expecting to have the Polks sound as good as or better than the OBs... I figured that "psychoacoustics" played a role in my switch from cabinet speakers to OB, and that the Polks would now sound better.
Man, I was WAY OFF. I'm still amazed at how the Heppners in OB put to shame the Polks. Brighter, clearer, more airy and open than the Polks. The Polks sounded dark,dull, distant. The Heppners were all over the Polks.
I do think that "psychoacoustics" play a role sometimes in making us "think" that the sound from a new pair of speakers is "better" than the previous ones. We "want" the new speakers to sound "better,"... hence, the effect of psychoacoustics. But this shootout between "old" Heppners and "new" Polks is stunning in the degree that the Heppners in OBs outperformed the Polks.
Just thought I'd share this. Thanks to you Open Bafflers!!
I've sent my Betsy's to Planet 10 (Nbiru?) for Enabl treatment and phase plugs. 2-3 weeks without my favorite drivers. Even worse, having to listen to crossovers and resonating boxes for 2-3 weeks! :( I can feel the twinge of a headache coming on now.
I'm not surprised as my first OB's ( Betsy/Alpha ) trounced my Zu Omens.
Please advise as to how the Enabl works out for you, I spent a ton of time in those threads but don't have the courage to try doing that on my own...
Will do. I also have spent tons of time reading the Enabl threads but I'm more of a visual learner, so it's all Greek to me. Supposedly their was a visual step-by-step tutorial at the Hawthourne Audio site but it's gone belly up.
I'd go lower
Tried 90 & am now near 65. I'm liking what I hear even if I only have a few minutes listening time. I'll sit and listen more after the heat drive's me inside. Seems to let the FR speakers do what they do best without the woofers interfering. Thank's
