Open Baffle Epiphany!
Either my digital music player or my AR XB into a passive input selector into the FX 01 to the APPJ mini to the Zenith's, I have been running the powered subs off the out from the APPJ because they have a high signal input. I've tried rolling tubes in both the mini and FX and it doesn't seem to make much of a difference in taming the shrill.
I would use Y cables off the FX preamp splitting the signal between the sub's line level and the APPJ.
I prefer a full range unadulterated signal going to the Zeniths. The sub's plate amp can cut off some of the low range signal since it's doing the heavy lifting.
Well, I'm feeling a little stuck in my zenith adventures. I've had them in open back box's, flat panels, and over the weekend I built a version of the Wild Burro folding baffle speakers and to me they are no better than the panels. They sound clear and extremely detailed and on most music are better than average, and the imaging is excellent, but the highs are still too shrill and on certain albums they are flat out un-listenable. The highs are so sharp that I have to instantly turn them down and it blows out my ears so much that I have to stop listening. Messing around with the wings, didn't really get me anywhere new, it just seems to be a more refined way of adjusting them in place rather than moving them around the room. Any guidance would be appreciated.
Have you tried listening to well off-axis, like without toe-in at all, or so much toe-in the imaginary beam crosses well in front of the listening position? Also at what point do the drivers cut-off or do they go all the way up to 20k (or your personal hearing limit)? With my 12" full ranges they sounded quite harsh and fatiguing by themselves, there was really two things needed to make them sound their best - helper tweeters, and not listening directly on-axis. It might sound counter-intuitive, but adding MORE highs above ~12k or so, made the speakers sound less bright, or less harsh. The way we perceive sound, all the frequencies we hear affect everything else we hear, for that reason it's really about the whole and changing something about midrange or highs even, will change how you perceive the bass to be etc.
EDIT: likewise, where is the bass cut-off, because if it's very high, it's possible it makes the mids/high-mids/low-treble stick out more and that will make for a fatiguing sound?
Me too. Just bass and treble augmentation in mine ;)
I like those tweeters. Are the open or closed back? Some of the closed models have a removable back.
They're closed back unfortunately with no way of removing the backs. Plat Audio RT4-DP. Planar I believe. 98db sensitive, 8ohms. Not ideal but I had them on hand. It's what I was going to use before I got the Skar Audio VX1-ST bullet tweeters, now I've both ;)
I've found adding more highs doesn't just smooth out the sound, though also gives better definition to the bass. Quite counter intuitive. My thoughts are that the brain doesn't process parts of sound well, so when the entire sound is produced we're able to hear more
I'm still not sure I have my Zeniths wired correctly. Anyone with a 49CZ, when looking at the back of the driver is the right terminal positive or the left?
With full range drivers the bass augmentation should come in so low that you don't notice it unless it's removed.
The 15" Magnavox woofers is my bass augmentation ;)
I'm probably not the best to answer this question as I don't have a red mark on either Zenith 49CZ802 terminal which should indicate positive. Mine have a white mark which is on the right side when facing the front of the speaker. But on my 8" Zenith the red mark is also on the right side and no white mark so go figure?
What's crazy about OB's is they can sound good in or out of phase. Much of their magic comes from that slightly out of phase back wave. Maybe someone else can chime in who has a clear red mark on their 49CZ terminal?
All my store bought speakers have the positive terminal on the left side when facing the front of the speaker.
Only one of my Zeniths have a red mark, however both have a white dot.... I'm wondering whether the red dot is an accident? Does the white dot usually designate positive?
You can check quite easily with a 9V, or just a 1.5V battery. With the battery negative connected to the speaker negative terminal, and the battery positive connected to the speaker positive terminal the cone should move forward. If it moves backwards you have the terminals mixed up. Just tap the wires onto the terminal to see which way the cone jumps. There won't be enough power to do any damage, even though it's DC.
I'm not running the Zenith's through the subs, I'm just splitting it after the power amp instead of after the pre. I tend to like the sound better this way, and my subs have a high signal input so there is no problem in doing it this way.
That's the right terminal. Is that positive on your driver? That is the one marked red on mine.... Thinking I might have them out of phase
I'm fairly sure the white on mine is the positive and I wired it as such. I guess they could be out of phase, I don't think so but I'll mess around with it later on today.
I'd feel really stupid if that was all it was.
I just confirmed that the terminals on my matched pair of 49CZ802's marked in white are indeed positive. Viewing the 802's from the front with their terminals on the bottom the positive terminals are on the right. The left negative terminals have no markings. This is the way mine have always been wired but the 8 inch Zeniths threw me off a bit as that same terminal on those drivers is marked in red.
:thumbsup:
This is close to what I'm talking about but without the passive X-over.
