Poultrygeist
Lunatic Member
Mmmm, mine are likely out of phase then. Will test my Zenith and Magnavox drivers when I locate a 9v battery.
I used a D cell and it works just as well.
I've seen them popping up also though their frequency response is nothing to get excited about.
I am intrigued by some of the Chinese Diatone P610 clones. Have a little 6" one coming to try. The 10" one looks fantastic for the cost too.
It was recommended that I try adding some tweeters, but I don't know if masking the problem with more speakers is the answer.
Any further guidance on this would be greatly appreciated.
I feel like I'm missing out, I'll keep trying to break in the new setup, but it's coming along slowly and I'm not really enjoying the sound very much at the moment. I'd like to add some big 15" woofers in an H box to support the low end, but until I can figure out why I'm getting such piercing frequencys I don't want to spend the money on them incase I can't overcome the problem.
The Hammond B3 tube organ is the best jazz organ of all time. It uses big alnico full range drivers just like the ones we covet in our OB's
They both seem like they are working OK, and I agree about the tweeter business. I'm hoping it's the amp needing to be worn in a little. I don't have another low watt amp to test them out and I'm weary to try them out on my big amps. But at this point they don't sound like they should.The Zeniths should sound excellent straight off the amp. That's not just my experience but it's also Mr Glow-in-the-dark's preference. That's the way he configures his. Have you listened to each speaker separately and can you determine if one or both are faulty? Be reminded your Zeniths are at least 62 years old and bad speakers can play music but still be faulty.
If they don't sound good by themselves which they should, tweeters or woofers will not improve things.
We use the term full range driver but we really mean wide range driver as no speaker is truly full range. The Zeniths can however cover a bunch of octaves on their own.
Wimpified Magnavox version.
It isn't hard to guess which one has a lower Fs, higher xmax, along with more power handling.
