Open Baffle Epiphany!
The FR Phy drivers in folding wings
They do look very nice.
Wish I had a room that big with that much space.
I was wondering how much bass is lost if they are shorter.
Gah, received my new Lii Audio W15 OB bass drivers..... I never fully appreciated how heavy 25kb is per driver. Going to be fun getting them home from work without my wife knowing. Heck, the speakers they're going into are heavy enough as is being made of solid hardwood. I don't think I'll ever move them again once these monsters are installed. I hurt my back just getting them out of the packaging as is.
I made a pair of OB speakers using a pair of MB Quart 6-1/2” coaxial car speakers. Car speakers made for installing in doors, dashes, or rear decks can be used in an OB as they are a “free air” design and don’t require an enclosure. As long as your amplifier can handle the lower impedance which is commonly 4 ohms.
Car speakers can sound really nice in OB's even 6x9's.
Yesterday my wife was working on a presentation for her garden club using this folding poster board from Walmart. I thought to myself what a good idea for test baffles. The size looks right and they look sturdy enough to support a lightweight driver. Two glued together could be a permanent solution. Someone should give them a try.
images
Hopefully I'll have time to install on the weekend. I have to enlarge the holes for them to fit won't fit as they are :(
And that my friend is no easy task. Scribing the correct cut out over the opening and accurately cutting it out with a jig saw is a real pain. There's a better way finding the original center with an extra piece of wood and then using a router and circle jig but I've never had the patience for that.
I'd mark the mounting holes before you start cutting. Nothing worse than not having enough material for the screws to screw into.
Might you back mount them?
And that my friend is no easy task. Scribing the correct cut out over the opening and accurately cutting it out with a jig saw is a real pain. There's a better way finding the original center with an extra piece of wood and they using a router and circle jig but I've never had the patience for that.
Indeed a pain. Especially for apertures of that size. I've had fair luck using a rasp barrel on the end of a drill. You won't get a perfect circle, but you can slowy shave the hole until the driver fits.
I've done that with a Dremel. If the original hole is close you might be able to sand enough material away.
I did try this, back in July (link with photo, below). I was working with modest sized wall speakers, so I cut it in half. They are good for a test. Pretty floppy. Two glued together would be a lot stronger. Would need a decent base for support.
https://www.audiokarma.org/forums/i...baffle-epiphany.566879/page-158#post-12905423
After speaking to Lii Audio they've advised I'll need to wire up both terminals. I've more Duelund wire coming to address this. Likewise the additional power provided by the Behringer KM750 won't go amiss. The ratings of the amp are for peak power so RMS ratings will be more like 100WPC into 8 homs or 200WPC into 4 ohms. I'll wire the driver coils in parallel so the amp see's 4 ohms. I've some Neautrik Speakon connectors on the way too so I can get these wired up safely to the amp. Prevent my bably pully the wires out once she begins to crawl.
On another note my Melo David P1010 drivers were returned to sender. The airport in China wouldn't allow something with such a strong magnetic field through. Quite strange as I've had no such issues when I got the big W-15 woofers from Lii Audio. I've receive a refund and ordered a pair of Lii Audio FAST-10 drivers instead. More expensive though they'll likely perform better anyway and will definitely get here quickly.
A shame though as I was keen to try the 10" Diatone P610 influenced drivers. From what I've read and heard the Lii Audio in a few places the sound from the Lii Audio floats in the air in front and above the speakers so I believe they're more forward than the Zenith which I've found very laid back. Probably the only drivers I've used where I can't hear the speakers however I would like a little more excitement. I believe the Lii Audio will give me that in comparison.
I'll likely hang onto the Zenith's in perpetuity though as they may well outlast the FAST-10 which say they last 10 years. Hopefully they'll last a good deal longer though time will tell.
