Open Baffle Epiphany!
I would guess about 96db on the the Zeniths. They do take their own sweet time to break in. IMHO they need to be played every day. I left mine for two weeks this summer and I took them about six hours of playing time for them to get back to sounding sweet.
Ah, possibly where mine went wrong. They only get a few hours use per day when I get home from work
It surprised me that the Lii Audio drivers seem to be the same. They don't like long periods of inactivity. Start to sound slightly dull for the first 30 minutes to an hour if I don't listen for at least a little bit each day. This might also have to do with the fact that the basement is getting fairly cold as we head into winter in MN.
I've not noticed that. They just seem to keep getting better and better. It's summer here though and they get a few hours use every day
Those Lii audio drivers look interesting, That 15" full range might be interesting. I had the Audio Nirvana 15 for a while but could never listen on axis they had a screach in the upper region. I had them pointing up at approx. 50 degrees and they sounded very good but when I would stand to go get anything it was obvious / overbearing, I know the lowthers can be the same but it was to good a deal to pass up. I might try my hand at wooden horn building I have a lot of left over oak flooring that could make a very nice horn. :confused:
Hmmmm, yes the Dayton PS220-8 are hard to listen to on axis for the same reason. Thankfully the Lii Audio Fast-10 exhibit none of this behavior that I can tell.
Mine only get a couple of hours of use each day, and sound good. To me it seems like if they don't played for two or three days or more they need time to loosen up again. Not near as much time as the original break in though.
That would be cool to hear your results. The zeniths can have some harshness that should go away as they break in, it can take a long time so let them run as much as possible. When they smooth out they are very impressive. I run mine in open baffle with subwoofer support. If I get a SET amp I might look to run separate signal to plate amp maybe diy subs in an effort to get set amp direct to zenith speakers.
A single ended amp is a must with the Zeniths. I've tried mine on low watt SS amps and they sound good, but not near as good as with my Zenith 5G29. The speakers and the amp came from the same console, so basically they were designed for each other.
I rather suspect that's true of most high efficiency full range drivers. Certainly true of the Dayton PS180-8, PS220-8, Liu Audio FAST-10, Zenith 49CZ and a pair of old Plessey Rola drivers I have.
The only amps I've used where they really shine are:
Wavebourn Edelweiss-3 (SET tube)
John Lindsay Hood 1969 (SET solid state)
With the Wavebourn in particular I find the quality of the source to be critical to getting the best from it. The JLH is more forgiving. I use both with 1980's era Phillips based DAC's. They just sound more real than modern DAC do. Less digital.
Full range speakers tend to be very revealing, a clean source is imperative. I mostly listen to vinyl, but I do have a music server with a Creative X-Fi card in it. It really surprises me how nice it sounds with high but rate MP3s. I actually like it better than my Wolfson WM8740 equiped Cambridge Audio CD player.
A mate brought a 2A3 amp over a few months ago. I loved it. Very rich sounding. Strangely he was not able to hear the difference from my KT120 push/pull amp which is a very different sounding amp. It should not have surprised me though as he'd been on the hunt for a different DAC and every DAC he tried sounded the same to him. The differences were large enough that I could identify them in the first minute of playback
Funnily enough I've found the output and tube coupling caps are critical in my Muji Studio Dac II. I've Miflex KPCU-1 in there presently though plan to bypass the output caps with Duelund silver bypass caps. I'm also going to relocate the caps using shielded Van Damme coaxial cable as one of the caps is against a transformer and another against a tube. Heat tends to kill caps over time and there's limited space.
I'll have to nestle the output caps amongst power cables so will wrap them in mu metal.
In some Asian countries the 2a3 is called the "queen of tubes" while the 300b is referred to as the "king". The 2a3 is known for it's finesse and higher resolution while the 300b has more body, power and warmer mids. Both are big bottle tubes, look much the same and are DHT's ( direct heated triodes ).
They're both nice. 6AS7 are great sounding also. I really wish there were more OTL amp designs. There's really no affordable OTL designs that I'm aware of. The closest is the Linear Tube Audio offerings which are kind of an evolution of OTL
OTL's are excellent but the cost of all those tubes and the heat they produce are drawbacks.
