Goggle1824
Well-Known Member
I'll likely hang onto the Zenith's in perpetuity though as they may well outlast the FAST-10 which say they last 10 years...
Their drivers have a 10yr life expectancy?
I made a pair of OB speakers using a pair of MB Quart 6-1/2” coaxial car speakers. Car speakers made for installing in doors, dashes, or rear decks can be used in an OB as they are a “free air” design and don’t require an enclosure. As long as your amplifier can handle the lower impedance which is commonly 4 ohms.
PureAudioProject is good stuff indeed.I came across these recently. Look rather nice:
http://www.pureaudioproject.com/product/15inch-open-baffle-bass-woofers/
Ok, my active crossover only does 24db slope, sounds amazing but I'm dialing back a lot of bass to take out an obvious bump in the mid/low bass frequencies. Low bass is taken by a sub so all good there. What would using a gentler slope achieve in my setup??Before going the passive route I'd try the active using a gentle slope.
anyone know the sensitivity on the Zenith 49cz line ?..............................Im loving my Jordan Eikoa 2, Im running into sensitivity issues with my Decware SE84c amps distorting at higher levels the Jordans are around 85 db1 watt..................All is fine till I go to play Vinyl and the low output calls for higher volume, sounds great at lower volume but Pink Floyd or Led deserve a bit more Volume
So 96 dB sensitivity is based on Glow in the Dark audio website and he seem to be making an estimate. I’m currently pushing them with a console amp about 5 watts and I have tons of headroom. I want to get a set amp probably a decware se84ufo I suspect it will drive the zeniths easily.Thanks gents. I have a pair on the way, along with lowthers now![]()
That would be cool to hear your results. The zeniths can have some harshness that should go away as they break in, it can take a long time so let them run as much as possible. When they smooth out they are very impressive. I run mine in open baffle with subwoofer support. If I get a SET amp I might look to run separate signal to plate amp maybe diy subs in an effort to get set amp direct to zenith speakers.I can let you know I use Decware se84c earlier version of the current ufo, I have a pair & run in monos for 6 WPC. I ca easily check on stereo at 2 wpc after I geet the 49cz in house
