Open Baffle Epiphany!
I have two pairs of Coral Holey Baskets and I've been meaning to try them out in an open baffle, two speakers per side, and wired in series. It would be a fun little project. Any tips for the simplest baffle set up possible? My main concern is that I don't have as much room to put the speakers out into the room as much as I would like. I would think, regarding room acoustics, that dipole speakers would greatly benefit from enough room behind the speakers as possible.
Best,
Jonas
Do you think two per baffle would be a bad idea? I suppose I could just experiment and see how it sounds
I've never tried using two of the same drivers in each OB but with conventional speakers it's avoided due to the effects of comb filtering. With one Holey Basket per side you'll get more than enough output and a large soundstage that belies this really small driver.
I've read those gorgeous Daytons require a corrective circuit to sound their best. The Betsy's OTOH were designed for OB's and don't require any correction. I really like the B&G Neo 3's and they would probably work well with the Betsy's.
Ranking my favorite OB full range drivers bi-amped and paired with the work horse Alpha 15a woofers:
1 - Lowther DX3 and Zenith 49CZ802 ( a tie but very different drivers - hyper detail and in your face Lowthers vs the golden toned Zeniths )
2- Coral Holey Baskets ( amazing clarity and detail - sounds like a much larger driver )
3- Zenith 8" ( alnico motors and a smooth cone but no model number )
4- Radio Shack 40-12860 ( real sleepers and I need to do more experimenting with them )
5- WBAL Betsy ( excellent choice with high Qts and other than the big Zeniths they're one of the few that could get by without helper woofers )
6- Tang Band W8-1808 ( very smooth and refined full ranger but too laid back for my tastes )
7- Fostex Fe126En ( a detail freak but perform best in a BL horn )
Hello PG, nice writeup, i just recently bid for zenith 49cz873 and cannot wait to set it up, my sony corals will be later in a frugal horn setup. I am planning to add super tweeters to these zeniths.
Have any one added RAAL 140-15D to zeniths? Reason for RAAL's coz in future i also plan to experiment with lowther pm5a (Tiny Alnico Open Baffle) in an OB.
I wouldn't hesitate to try it. Several audio buddies were present when I ran a clip lead experment, going from 1, to 2 and then to 3 drivers. All liked more, without a question.
Simply mount the drivers as close as possible....almost touch the lips.
The comb filtering question simply isn't a problem at all. You can find evidence of it with a mic and an analyzer, but up close only. At listening distance and maybe more critically, using open baffle, there just isn't a problem. And imaging in the end is a strength of multiple drivers not a limatation.
I've run three identical drivers and then four, (to get back to an 8 ohm load) for many years now. And lots of guys have heard it and never remark on any problem from multiples. And several have even converted to OB with multiple drivers too.
EV3
I forgot about these Tekton hybrids which use multiples of the same driver. They sounded great but no better than the single driver Fostex Tekton also paired with the H-frames shown in the next post.
I am going to build a pair of OBs with these drivers but don't know how to determine what the LE is to determine if they would work in OB. Anyone know how to find that. It is not on any literature I've found.
Thanks, it can’t hurt to try. My friend has a pair of Bastani Open baffle speakers with two 12 inch drivers and then subs underneath. They sound sublime. No comb filtering that I notice.
best,
Jonas
EV3
View attachment 1795685 View attachment 1795686
LE? What do you mean by that? If you mean the voice coil inductance, I don't think that's the most important parameter for OB use. The parameter that matters most is Qts, the total Q factor of the resonant peak. It can be measured by using a signal generator and an oscilloscope, but I've found it difficult to get accurate readings that way. The modern way is to use some software and a computer with a full duplex soundcard, or I think there's a device available from Parts Express that will do it for you. Not sure how much that costs. I use some software called LIMP.
What's the best Qts for an open baffle? There's some debate about that (as always) but > 0.7 seems to be the consensus.
This article analyses Qts for open baffles:
http://www.hi-fiworld.co.uk/loudspe...udspeakers-open-baffles-and-bass-part-15.html
Let me first confess that I have only read the first 19 pages of this thread so far. After several more days I hope to catch up to here. Meanwhile, a few observations and questions:
1) While the original poster began by experimenting with mounting speakers in various sized corrugated cardboard boxes with their backs open, and then some corrugated cardboard winged panel designs, there seems to be a vast number of ideas/designs used by people who are making, and sometimes, selling Open Baffle speaker systems, from arrangements not much wider than an ironing board stood on end, to others that look five or more feet wide, suggesting the configuration of the panel system the speaker (or speakers) are mounted through is real, real important. Then others have little more than the speaker(s) held up my some sort of framework/scaffolding/brackets, suggesting such a panel system is not important and maybe a hindrance. In the first 19 pages, I didn't gather a clear idea for how these seemingly contradictory ideas for Open Baffle designs have merit. It doesn't seem that both can be right.
2) I'm old enough to remember when radios, radio-phonograph units, and consoles including a turntable or record changers had open baffle speakers for one simple reason -- the company simply didn't put any sort of backing panel or the rear of the furniture. In fact, I grew up with an open baffle speaker, because the cabinet my dad built with a shelf to hold the kit tube amp he and my older brother built (and which they only built one channel of, leaving it a mono amp forever), had a big boxy space below the shelf for two speakers. And since, the amp was mono, only one dual cone 8" full-range Jensen speaker went in that big space, and the back of the space never got covered. We were mono, tube-amped, and open-baffle before it was cool. I wish I could hear that set-up again. Maybe I didn't know how good it was. My folks just just said "It has a good tone."
3) I wonder if anybody has just taken the back off of box speaker that had so-so sound, or some particular and frustrating deficiency, and found that it suddenly sounded much better. If people have done that, it might be interesting to know about such examples.
4) I also noticed that none of the open baffle designs I saw pictures on the first 19 pages of this thread, or pictured in linked pages I looked at, ever showed any kind of grilles or fabric over the fronts of the speakers. I get the impression having anything whatsoever in front of or directly behind a speaker is against the open baffle philosophy. I also get the impression that dedicated open baffle enthusiasts do not live with pets, children, or elderly persons of an age when they are getting clumsier and clumsier by the day, because in those circumstances (in my experience), if there is an unprotected speaker cone, it will get a hole poked in it, or get torn, or otherwise get damaged. So I am wondering, whether there exist any quasi- or heretical sort-of openish baffle speaker designs that provide the speakers with sufficient protection to survive in the hostile sorts of environments the rest of us live in?
Sorry Roth, I meant Qts.
The sides of a "backless" box form a resonant cavity and it can sound truly awful - been there, done that. That's why open baffles with wings usually have the wings at about 45 degrees.
I guess that is why the OP migrated from speakers in open cardboard boxes to winged cardboard panels....hmm? So, if you were starting with a closed box speaker, you might need to shorten its depth quite a bit, like until what had been its sides were more little more than a frame holding the front side the speakers were in, not leaving enough boxness to seriously resonate.
I would think there might be other ways to reduce or stop resonance though....
On over all design choices...let me add from my experience that the larger the baffles get, the more they intrude into the way they sound in the room. Kind of a divider almost between the front and back radiation pattern.
The reason for bigger, is to address how you're getting bass which also involves how low you're attempting to go with it. A choice depending on if the OB is it...or if you intend to add a separate subwoofer to augment. Too small to none-existent and it's probably going to need support way higher...or it's got a big way up woofer that rolls kind of soon even for it's size.
A number of ways to get bass and even at that, some just are happy with the really nice imaging and soundstage of mids and lack of resonances and don't worry about the lower freq's at all. All valid if it makes you happy and gives you reproduction that works. The point is that once you get rid of all the reflections of the box that when used to it, you'll not ever want to go back!
EV3
