Open Baffle Epiphany!
Quick question, I built my open baffles about 6 years ago and they have been in storage for the last 2 years. I took them out over the weekend and my Yung SD200 blew a fuse right away. It has blown 4 more the second I plug it in and turn it on. A little research online and it seems like this is an unfixable and common problem and parts-express does not carry them anymore. Does anyone have a replacement plate amp that will work in place of this one? I don't necessarily need 200 watts, 100 would probably work just fine. Anyone else had this problem? What other type of amp could I used in replacement of the plate amp?
I like the Crown XLS amps they are super flexible and do superb on bass duty
The Yung plate amps are still for sale on the Parts Express website. I had one that did the same thing and they sent me a replacement. I have four of them and they've been reliable although recently I mistakenly ran four Alphas in parallel from a single Yung SD300 and it overheated. Haven't tried it since but a 2 ohm load is not recommended.
Thanks Poultry, I don't see the 200 watt one (SD200-6) anymore but they do have the 100 watt. I liked that amp and at that price it's almost a no brainer to just replace it every 6 years. But I also don't want a lemon is that is what they are, but it sounds like you have some trust in them. Thank you for your response.
Good imaging to me is the ability to pick out instruments in the soundstage. With OB's you get great depth and holographics. Often you can hear instruments that appear to be placed behind, to the sides and above the OB's. Some believe that skinnier baffles can contribute to better imaging. I can't say because all my baffles at no wider than 20 inches are on the skinny side so there's nothing I have to compare them to.
Well thanks to so many I've completed my 3 panel OBs with the AN 15 full range stop of the Eminence Alpha As and like them more than any speakers I've owned. Everything sounds as I hoped from the descriptions given hear. I can't thank everyone enough!
Now I have a new goal. I want to be able to switch between two different amps to drive the AN 15s. I recently hooked up an Allo volt+d and it provides tighter bass and slam as well as higher highs but of course lack the glorious old fashioned midrange bloom as my tube amp. I'd like to use them both for fun!
I thought but have yet to receive an amp switching box to connect the speakers, but since I am using only one source with one pair of rca outs I also need a way to connect the rca inputs on each amp.
I currently have a nice volume attenuater recommended by a member with an rca input for the dad and rca outs connected to cables with a y splitter going to my tube amp for the ANs and the Crown amplifier driving the Alphas. This seems to work great since I can control the volume with a singled nob and the relative volume of both the ANs and Alphas easily.
With the current setup I'm good hooking up speakers to the switch box so I don't have to change speakers every time I decide to use the other amp, but stuck with turning off the current amp and switching the rca input cables to the other amp, then turning it on.
After searching and trying to figure this out I came up empty... UNLESS I split the signal from the volume attenuator that drives the main amp (for the ANs), which was already split to provide signal to the Crown, so that is can connect an extra set of rca cables to the other amp. So then when is select amp A on the switching box the signal will still go to both amps A and B but won't be passed to the speaker outs on Amp B (and vice versa).
If anyone has any advice on if this would be safe and not too sound degrading I'd love your input. And if anyone has any other suggestions let's hear them!
In any case I just want say thanks again. I haven't been more interested in actual stereo equipment since I bought my first real stereo over forty years ago: a pristine pair of Mac MC 30s for $150 and a pair of Fried A transmission line speakers. That's saying something.
Glad the OB's are working for you. One word of caution if using an amp switcher with a tube amp. The tube amp must see a speaker load when it's on. If you forget to turn it off when playing the Volt it may not survive.
I have been able to solve several switching issues with a $99 Chinese passive preamp with multiple inputs and outputs and placed upstream of a single input tube preamp. It has proven to handle all my switching needs and is totally transparent.
https://www.ebay.com/itm/Passive-Pr...368408?hash=item2d1d602498:g:FI8AAOxySE9Q50ON
I decided to give the open baffle a try. I pulled out some 12” vintage Sound Craftsman full range drivers and baffles. They are just leaning against a coffee table for now until I can make base for them. I know, I didn’t put a lot of effort into it but the results were good enough to want to listen to them for a while. Sounds great with classical music. Listening to Yo-yo Ma right now. Why did I wait so kind to try this?
Nicely done! I’ve been thinking about adding a low frequency driver to extend the low end a bit. Eminence Alpha seems to be popular. What are you using in this set up?
The OB bi-amped system includes 12" Zenith 49CZ802 alnico wide band drivers over Eminence Alpha H-frames. Realistic super tweeters firing to the rear, wired out of phase and balanced off with front firing Eminence ASD 1001 compression tweeters.
Started out as a proof of concept with the Zeniths in OB's.
and eventually they became this.
Also, do you
Cool, what are you doing for crossovers to the Alphas?
I use either a plate amp with built in crossover or a conventional amp + active crossover. No filters on the Zeniths and run them full range straight from their flea watt tube amp.
Thank you Sir!.
Do you believe the depth of the h frame has impact on the performance of the alphas or bass drivers in general? As I’m still in the proof of concept phase myself, I was toying with the idea of mount both driver on the same baffle sans h frame. Any thoughts?
Yes, I'd say a single Eminence Alpha per side in H-frames has about the same bass output as two Alphas per side on a flat baffle. I've only used a 17" depth for the H-frames and I wouldn't risk going with less.
