The simplest way to get a 6db/octave crossover is to put a capacitor in line with the + of the fullrange driver. I couldn't find the impedence of the driver online, but if it's 8 ohms, a 200uF cap would give you a 100Hz crossover, if 4 ohms, you'd need a 400uF cap. Those are big caps, and likely you'd have to use electrolytic caps, which don't have the best reputation in this type of usage. But it's certainly worth the experiment. (P.S. I used this calculator: https://www.diyaudioandvideo.com/Calculator/SpeakerCrossover/)
Another simple way would be to use a cap in line with the input of the SET tube amp. So if it has a 100k input impedence, the calculator indicates a 0.02uF capacitor, which is much easier to find in an audiophile-approved type.
Hope this helps,
Pete
P.S. Cool project - how did you get the pattern on the front?
Hope this helps,
Pete
