Open Baffle Epiphany!
Finally got the 852 OB's and H-frames done. As gleaned from those here, H-frames for the Alphas, Y-connectors and a couple of plate amps mounted directed to the enclosures. (Might make enclosures for these later.)
Thanks to Gordonw, the Dynaco and Magnavox sound terrific. Smooth as hell, and plenty of punch.
Played these all day today. Absolutely no sense of fatigue. Just addicting, even streaming through the headphone jack of my laptop, since I haven't decided on a DAC yet.
Any DAC recommendations for this setup?
Thanks to all.
Just ordered the Khadas. I had tried an Audioquest Dragonfly Black, due to excellent reviews online.
Really sounded awful...canned...compressed, etc. Played with settings, etc but just underwhelming. The headphone jack on the laptop was significantly better.
Hope to have better luck with the Khadas.
Border Patrol SE-i or if you can find one Line Magnetic LM502ca Dacs are both very good No Fatigue and the both compete with Vinyl playback quality. the BP has limited connections and only does 96, the LM502ca has much better connection offers SS or tube output and will play up to 192 files................
Either DAC competes with some costing as much as 8K IME and IMHO
At $89 the Khadas Tone Board goes toe to toe with far more expensive DACs. USB and a single coax input somewhat limit flexibility. Love it paired with the Node 2i streaming high resolution content from Amazon Music HD.
Just curious what other "Far More Expensive DACs" have you compared the Khadas to ? I am always interested in new dac designs, but my music tastes usually keep me in the NOS camp although I found the LM502ca has the ability to sway me from that camp.
I have heard far more expensive dacs than the LM502ca and the BP SE-i and I frankly agree that with DACs there is a definite line to the diminishing returns theory.
My other more expensive DAC's are a Modi MB, Topping DX3 Pro and Audio GD NFB.
Greeting,
I have followed this forum, but never posted. I have a foursome of these speakers, and have looked for info on them, but I have never really found anything.
In the last few years, I have only seen a total of 6 of these speakers come up on ebay from 3 different sellers, and I bought 4 of them, and almost the other 2, but one of them
had damage, so I passed. The only association I have come across is that they seemed to have been used by GE in their Vacu-Magic stereo consoles, but their codes on the speakers
have evaded identification. I don't have the equipment to determine their specifications, but they are lovely sounding and very efficient. In my baffles, they will reach 50Hz. without help. With my McIntosh MQ-102, that boosts the low end at 20Hz., I can reach a robust 40 Hz. and a hint of presence at 30 Hz.,
but lately I have just enjoyed them without augmentation.
All 4 of the speakers have the codes that show on the back of the one. In my quasi-open backed baffles, there are 2 of them, one above the other. The bottom one is in
an added baffle that the top section is bolted to, which was the shell of a Klipsch Heresy that holds the other 12 inch plus a small cloth dome tweeter with a 6db filter capacitor.
The bottom 12 inch has a coil that rolls off the highs to cut reflections from the floor interfering with the top 12 incher, that runs full-range without any crossover.
Recently I tried a pair of the Lii Audio F-12's in the top position. Though the F-12's were very detailed, they could not match the warm fullness of my old Alnico's.
So, has anyone ever seen any of these speakers, or know anything about them?
Thanks for your input:beerchug:
My latest project, Lii F-15 up top and Lii W-15 below, Currently running the F-15 Full Range, and Low Pass cutting the W-15 at 300Hz. Sound is best I have had to date. the speakers disappear in the room the imaging is 3 dimensional, almost holographic. Still pondering a finish
View attachment 2175719 View attachment 2175720 View attachment 2175721 View attachment 2175722 View attachment 2175723
Those look quite spiffy, precise, and I bet they are going to sound wonderful!
Hi
I’ve been reading a lot on this friendly site but I don’t post often.
Quick question about Zenith 49CZ860 and 861.
We often see these 2 drivers used in a few Zenith console, often connected in parallel to a mono amplifier. Since these have 2 different model numbers, do they sound the same? I’m planning to buy a set (1 per side, stereo setup) unless someone confirm that they sound different.
Thanks for your help
Eric
Hi Eric,
Are those the ones on ebay? I have seen them and wondered what the difference was myself. They looked about the same. Did you get them? I have read that the 860 is supposed to
be a gem. Crossing my fingers that the 861 is the very same!
Greeting,
Vintage alnico's can be very special. I've had such success with the Zeniths and Coral Holey Baskets I keep passing on the newer stuff.
Hi Eric,
Hi
I actually bought them locally. The drivers are not the same but very similar in sound. I prefer the 861 which is slightly warmer sounding compared to the 860. The 861 is a seamless cone and the 860 has a seam so maybe that explains the slightly different sound. At 10 feet away they sound the same (to me)
BR
Eric
FWIW my 12 inch Zenith 49CZ802 alnico's have ridged cones while the 8 inch Zenith alnico's ( model number blacked out ) has smooth cones. They were part of the same 1957 mono console ( predated stereo ) along with two alnico tweeters.
So, recently had a few drivers that I bought and did nothing with. Couple of cheapo Pyramid tweeters from a car project. Two Carlson Stromberg full range drivers. Had a couple of pieces of plywood, so I figured, what the heck.
Put them into my Dahlquist setup, using the LP-1 Active XO, and the Dahlquist sub.
Unreal....For a bunch of unremarkable drivers, the damn things sound pretty good! Not to the level of my other set ups, but surprisingly listenable.
Especially when listening to classical on the tuner.
