It is kinda quiet, is everyone just listening
For the record, my speakers are a combo of an old Klipsch Heresy's and an additional bottom cabinet that I added. Previously I had
replaced the original cabinet backs with pegboard. We have a couple cats that live with us, and I needed a way to sort of be
open baffle, but also a way to keep out kitty paws. Recently I started wondering that if even though the pegboard is obviously filled with
holes, could it actually act as though it were being actually a ported enclosure? I went to the trouble of calculating the area of all of the holes,
approximately 1/4 of an inch sized for each hole for each cabinet back,
and coming up with the area of the combined holes, and using the depth of the cabinet, as the theoretical length of the
port X the area, and it came out to be roughly a ported enclosure tuned to about 33-35 Hz for both the larger and smaller bottom cabinet.
Now all of this may be out in the Ort Cloud, but in case it had any validity, I decided to replace the backs of the cabinet with metal lath, which is
way more porous than pegboard. I still need a barrier for kitties!
Aside from the lath screening being a bit hairy to work with, I believe that my speakers did benefit sound wise from the change. Sound is
more open, an improvement to my ears. I also added in the back, two 3 inch Alnico tweeters in each top cabinet, wired in opposite phase to my front 1 inch
Mylar dome tweeter. All the tweeters are crossed over around 6-7K with a capacitor. The tweeters are of the same 1960's vintage of my 12 Alnico
driver's in the top cabinet, and I have an 8 inch Tang Band in the bottom cabinet. I like the sound of the Tang better off axis, so that is why it is in the bottom.
Both the 12 inch and Tang run full range. So that is the state of the speaker here. Next project is building a new tube preamp to see if it can unseat my
current daily SS pre. If not, I can certainly live with my SS, but sometimes you just have to try
Oh, one more idea to toss out...An engineer acquaintance once shared this idea with me. Add a copper bar to your speaker ground. Mine
in each cabinet is 3 1/2 X 1 1/4 inch and 3/16th of an inch thick. Actual dimensions are not critical, but he had told me that it would improve
the sound of your speakers. I bought the bar off ebay for less than $20 as I recall, but for me, I could actually hear an improvement in clarity.
I mentioned it once to the fellow at Nirvana once, and he basically told me I was off the deep end, so take it all with a grain or two of salt.
Just thought I would throw it out for consumption. I promise I am not invested in copper
Den
