Open Baffle Epiphany!
Or get someone to cut it for you! Chamfered/bevelled cut out is way beyond my limits.
Thanks for the direction.
Those fancy cuts are unnecessary as they remove some of the material that anchors the drivers. A plain cut out hole works fine. Home Depot will make all the straight cuts if you buy their plywood or MDF. Even a cabinet shop shouldn't be that expensive for a turn key job.
Those fancy cuts are unnecessary as they remove some of the material that anchors the drivers. A plan cut out hole works fine. Home Depot will make all the straight cuts if you buy their plywood or MDF. Even a cabinet shop shouldn't be that expensive for a turn key job.
Agree, going to get the Belgian equivalent of Home Depot to do all the straight cuts. Still going to get a professional to cut the holes. All in, the whole projects less than €100. Who knows where it will lead......?
Don't know why, but cutting circles is more satisfying than making straight cuts...
Trying a new assemblage. The Visaton 10 inch paper woofer is not a bad egg for open baffle.
It has 34 fs., handles 80 watts, a 5.5mm xmax, and has a Qts. of 1.43. It has a warm sound,
and is presently playing nicely with my 8 inch Tang Bands, and a 1 inch mylar dome tweeter.
If you haven't got room for a 15 inch, which I don't, it is a descent speaker for around $44.
The screen covers protect my speakers from kitty paws.
Well me being me a some what half asleep human being more times then I like to admit bought a set of mark audio alpair 12p was wanting the 12pw which is a woofer to complement my audionirvana 8 alnico. So my thought is use the alpair in a open baffle anyone try this driver in a open baffle? I have a dbx 120x think I could use this to crossover to the woofers and run them from 120 hz down. Any thoughts would be appreciated.....
It sounds like that would work. What are your woofers? I am not familiar with a dbx 120x, but I assume it has the active crossover that would allow you to do this.
The woofers in my open baffle just use a coil to roll off the highs, but many members use active crossovers in their setups.
Their qts is only 0.285 so they might (probably will?) sound thin if crossed that low.
Looks like I'll build a box for them kind of thought that as I really can't find much about them in a open baffle .....
You could try a cardboard baffle to get an idea of how much bass your speaker would produce. I have read about people using low Qts. speakers in open baffle with results
they found acceptable. It really depends on personal preference, though the higher Qts. is a reliable indicator of more substantial bass output. It is an engaging pursuit to try
new ideas with open baffle. I tried for well over a year to tailor the sound of a pair of Klipsch Heresy's into something I liked, but it finally drove me to remove the backs of the cabinets,
and it opened the doorway to actually hearing something worth pursuing, hello to the idea of open baffle! I couldn't have been more pleased than when I was finally released from
the sound of boxy sounding speakers.
I could switch the audionirvana 8 alnicos I have with the mark audio I do like the AN in there box though.a idea I have is having the AN running open baffle and the MA in a enclosed box firing up behind the baffle not sure about mixing drivers like this ? Might be worth a try..like this
https://images.app.goo.gl/YBdkF29ifCEAJNK18
Once had a pair of the Tekton Hybrid OB's and they required bass augmentation. As nice they sounded I couldn't justify owning them as I had better sounding OB's.
The Tekton hybrid OB's sounded much the same as these Tekton full range single drivers atop the H-frames. Both used the same Fostex drivers. That's another reason I didn't keep the hybrids. ( FWIW wife's sunroom not my listening room ).
Poultrygeist what problems would I incur using two different drivers like a an 8 alnico and a mark audio 12p if the base isn't there I could run a sub out of my dbx 120x ....
I am not trying to but into Poultry's input and experience, but I have not had problems using different drivers in the same speaker, but you would need to pay attention to the sensitivity ratings of the
individual drivers so that one would not overpower the other. I would also look at the peculiarities in response of the two drivers also. The real test is just trying them out to listen to how they
blend. I know Poultry has way more experience than I do, so I look forward to his insight.
