Open Baffle Epiphany!
You can buy flat pack U-Frames at Madisound
Yes, I'd say a single Eminence Alpha per side in H-frames has about the same bass output as two Alphas per side on a flat baffle. I've only used a 17" depth for the H-frames and I wouldn't risk going with less.
Ok, looks like I’ll be working on h frame! Thanks Poultrygeist!
Well, I hooked up my bookshelf sized OB's in my main system tonight powered by a little 10WPC JLH 1969 amp. For music it's absolutely glorious. Enough so that I think I'm going to rebuild these as floor standing units with dual 10" woofers.
While the Zenith simply didn't work in my main system with the shallow open back cabinets, with a traditional open baffle they're absolutely spectacular. I feel nothing is missing for music playback. For movies on the other hand they leave a bit to be desired which is where dual 10" woofers would come in, with plate amps.
I'll have nothing but open baffles in the house eventually at this rate. The project will have to wait a few years until the little one is a bit bigger though.
From what I could gather there, the set does not contain the actual woofers or drivers.....just doesn't say sold separately anywhere.
Kevin
Well, I added Dynamat Extreme (well the Chinese equivalent) most of the way up the inside of the sides of my shallow open back cabinets.
There's been a noticeable improvement in bass. Deeper and more body. Not sure if it's the added mass, killing vibration or the smooth aluminum reflecting sound waves better out the back?
Likewise the sound is a little more engaging. A little less laid back while still retaining the open, detailed sound I value so much with these.
In truth a big part of the reason for doing it was so my toddler couldn't push the entire frame for the speaker cloth in till it rested on the motor for my fullrange driver. It's just had added sonic benefits is all. :)
Kevin
Actually it says this at the top of the page:
"Pair | Liionidas Open Baffle and XO Without Drivers | Simple and Musical Complete Solution"
So it's the baffle and crossover only. Drivers bought separately.
Sorry if this is the wrong place to post this question but I wanted to try a simple way to roll off my full range driver to around 100 us. Thanks to this forum I was able build a beautiful pair of simple OB speakers with an Audio Nirvana 15 inch Classics paired with Eminence Alpha A's, bi amped with a single ended tube amp and a Crown XSL 1002.
I truly love them, and again, building them as a true beginner was a joy, especially during the time of my mother's death, was very meaningful to me.
Enough sentimentality ! Just out of curiosity, I'd like to try a very simple, reversible way to roll off the AN full rangers at about 100 hz just to hear the effect. If someone could suggest the proper speced quality capacitor, and how to install it, or any other simple solution, it would be most appreciated.
While I'm at it, I would be open to measuring and trying to eq either or both drivers, as I have heard many times that OB's simply need eq. So if there is any discussion, learning, tutorials, etc. at a genuine beginners level, that would be great too.
Mind you, I love these speakers, and am mainly just wanting to learn and explore possibilities.
Thanks again to everyone (you know who you are) and to this great space.
