Open Baffle Epiphany!
I am building a new baffle for the Zenith's that will sit on top of my woofer. Previously I was using a modified Klipsch cabinet for an unknown full range alnico,
with an additional front firing tweeter. I also had two 3 inch alnico paper cone tweeters that aimed rearward, wired out of phase with the front tweeter.
According to conventional wisdom, the Klipsch cabinet with the back removed should have sounded terrible, but in my arrangement, it sounded
good to me, and also removing the back of that Heresy was my first step into the world of un-boxy speakers.
So the new baffle will be around the same size as the heresy, around 15 1/2 by 21 1/4 tall, sitting on top of the woofer except it will only have sides 5 1/2 deep.
From some comments I read over at Glow in the dark, that fellow had used the Zenith, with an additional from firing tweeter also. He came to
decide that the front tweeter was confusing the sound, and thought that the overall sound was more focused without the tweeter.
Based on that, I am going to drop the front tweeter, but still keep the 2 rear firing ones with phase reversed, so we shall see how this new
arrangement pans out. I would think that the sound from the Zenith should have more of a dipole character in the new baffle, but if it is not
to my liking, I can go back to the original cabinet. Options are always nice. All in all, it will be around a $60 dollar experiment, not including the new old Zenith's!
make sure to pull them off the front wall as much as possible. Kevin at Glow in the Dark is "REALLY" into his Lii F-18, I have a pair and they are good. I put the Vox in a temp baffle, approx 20 hours in now and they are superb. with the Oliver Sayes 71a driving them from 150 Hz & up. Source is a AudioGd Master 7 and files from the PC. its nirvana.........
New baffles in progress.
Looking Good, Too DAMN Hot & Humid to do anything outside here in NC...........................I remember as a kid, Young adult we never cared about heat, bugs, comfort or lack there of..................Today I walk outside and I am miserable.................At least I have some OB to listen to !!!!!!!!!!
Looking Good, Too DAMN Hot & Humid to do anything outside here in NC...........................I remember as a kid, Young adult we never cared about heat, bugs, comfort or lack there of..................Today I walk outside and I am miserable.................At least I have so OB to listen to !!!!!!!!!!
Here is south ga., it has been so hot and humid. I guess desire to hear these new speakers has motivated me to sop up towel after towel trying to not drown in my sweat:eek:
from the Linkwitz site:
Open baffle loudspeakers
  • Open baffle speakers are inefficient in terms of the mechanical movement that is required to create a given level of sound. This not only applies to speaker cones but also to panel vibrations.
  • Open baffle loudspeakers reproduce bass with less room interaction. It is more articulate than from box speakers.
  • If dipole behavior covers the full frequency range, then the room response becomes perceptually masked by the direct sound.
  • The radiation from the rear of the cone must not be absorbed, but the distance to the nearest reflecting/diffusing surface should be at least 3' (1 m).
  • An open baffle circumvents the box problems of delayed radiation through cone and enclosure panels. They occur typically in the mid-frequency range and are difficult to suppress.
  • Large panel radiators or long line radiators suffer from severe lobing at higher frequencies. It manifests in critical room and listener placement.
  • Even though a dipole requires a 6 dB/oct boost towards low frequencies, it takes little power to drive it to maximum excursion at its lowest bass frequencies. Amplifier power could be an issue as frequency increases, where it requires higher cone acceleration to reach Xmax. Thus SPL is limited by driver volume displacement at the very lowest frequencies and becomes amplifier limited as frequency increases.
  • Realistic bass levels can be obtained from dynamic drivers in open baffles, not from panels. For extreme SPL requirements the number of drivers could get very large and, therefore, below 50 Hz they are more economically replaced by sealed box subwoofers.
  • At frequencies where a 8" driver would become directional it has wider frontal dispersion for an open baffle than if the baffle were closed in the back.
  • Open baffle speakers reach deeper into the room and are less subject to the room response if their polar response is well behaved.
  • ORION exemplifies open baffle loudspeaker design in terms of polar response control and dynamic range. It circumvents the limitations of large panel radiators and yields a small package.
  • The low masses of the moving parts in an ESL, a planar magnetic, or a ribbon driver are necessary to generate useful sound pressure levels. The force generated by an electrostatic or planar magnetic motor is weak. Since SPL is proportional to air volume acceleration, and moving parts Acceleration is Force divided by Mass, the mass has to be lower if the force is too weak to generate sufficient acceleration. Furthermore, since excursion is limited with these drivers the radiating area has to be large to move a sufficient air volume.. These relationships seem to be difficult to grasp by audiophiles. Marketing departments and even some designers like to tout low mass as an inherent benefit giving greater "speed" or frequency response to their speaker, when it is only affecting sensitivity in SPL/W.
  • It is difficult to screw up an open baffle speaker design to where it sounds worse than your typical box speaker.
MJK's Lowthers over AE H-frames
Those AE drivers are sure nice looking, but pricey. I like the W-15 but I dont use an H-Frame currently. I get down into the 30's with ease. I am running a clone of the Spatial X-2 Style Baffle pictured here (Mine do not look as nice as these :)) YET
This set up allows for a relatively small baffle size, mine are 21 X 21 and stacked they are 44 tall x 21 wide. The design also lends itself to experimenting as you only need to replace the top half to try different FR drivers. I am able to remove the top driver, take one of the cutout discs, cut a smaller hole and then use shims to set the new disc in place tightly with the smaller driver attached
A thought I have is to try a audio nirvana alnico 8 and a mark audio alpair 12p in a open baffle .The AN 8 mounted on the front of the baffle and the mark audio mounted towards the back of the baffle recipe for disaster?
.........mounted towards the back of the baffle? :dunno:
Yes one forward one backwards guess like a dipole might help with the comb filtering.....
A driver mounted on an open baffle radiates both forwards and backwards, ie it is a dipole. There's little difference between what comes off the front and what comes off the back until you get to higher frequencies.
Thanks didnt realize it would be the same thought you would get less coming out of the back of the driver did do a little reading up after my thread not a good idea......
Unlike regular drivers most tweeters have closed backs and only radiate well in one directions. That's the reason I use one firing to the front and one firing to the rear ( wired out of phase ).
