Open Baffle Epiphany!
@dfoulk
Try the tweeters firing up and as Joe mentioned pull them out from the wall (5-6 ft if you can).
Hey there opnly bafld,
Those right sized holes for my tweeters cost me $40 for the hole saw, but if I still had the money and not Home Depot, I guess I wouldn't
be having the music of those old Alnico tweeters in my future!
Summertime heat and humidity are still over-rated in my book for building speakers, but the smell of good ole MinWax stain is
always a treasure of memories of projects from past til today:)
I am thinking that I oughta wire my tweeters in phase instead of out of phase since they are not opposing any front firing ones.
They will just have a blocking cap in line. How does that idea sound?
Den
So running 2 tweeters out of phase. are you using a simple 1st order passive crossover, off the same amp that is driving the Zenith ? if so am I correct in thinking the tweeters are wired in series ?
Joe
Yes will be running the 2 tweeters off the same amp with just a blocking cap, tweeters facing up
@dfoulk
I wouldn't have made holes on top, just mount them somehow so they could lay on the floor behind or on shelf behind near the top.
You have 2 tweeters per side? :dunno:
@dfoulk
Yes I have 2. I had two before on current baffle. May just use one on the outside hole, that really ought to be sufficient. Then just use the blocking cap
and wire it in phase with front Zenith. I recall seeing some old open baffle setup with the tweeter firing up. Will have to look for it.
The fun thing about DIY OB's is that you can try all sorts of variations with little effort and go with the set up that sounds best to you. You have far more laditude with OB designs than with conventional box speakers.
back Al (2).JPG front Al (1).JPG When the baffles are done, it will be time for the battle of the Alnico's. In one corner, Mr. Zenith, and in the opposing corner, Mr. Unknown, current reigning
champ. No partiality, just a good clean fight, and I will see who wins the top slot. I have been listening to Mr. Unknown for more a couple years, and have
brought others in for a comparison, the latest being the 8 inch Tang Bands, but the Tang Bands are back in the box to go to the sales department.
It will be interesting.back Al (2).JPG front Al (1).JPG back Al (2).JPG front Al (1).JPG
The Zenith Pictured is a ceramic mag. At least thats what I was told here. BUT I had both that model and the older style alnico. I honestly never heard a difference between the 2.............Sounds like a fun project
I wondered about the magnet on the Zenith. I wish I could find out who made my other speaker. I have searched far and wide, and asked many people. Even Glow in the Dark
had no idea. Audio Nirvana just said he didn't think they were any good when I asked him, too small of a magnet he said, even though I told him that they did sound very good
to me, but he was interested in selling me a pair of his wares.
The only place I ever saw them was in a GE Vacu-magic stereo console. Only ever have seen 6 of the speakers over the years on ebay, and I bought 4 of them.
The other pair had damage. The speakers were from different sellers. No manufacture's code that matches anything.
Den
Is that a faux wood grain finish I see on the baffles ? Looks nice. If it is can you share more info IE... what stain you used as a base and what stain for the graining, Also where did you get the graining tool ? any chance of aa link to the tool ?
Thanks
Except for the motor the Zenith pictured above looks the same as the 49CZ802 and 852.
Alnico motors fell out of favor probably because they are more expensive to produce. Few new alnico drivers are used today in home stereo. Below is an exception in the 4" $750 Fostex anniversary model which looks similar to my Coral Holley Baskets. You do see some alnico drivers in pro audio primarily with guitar amps.
A few pages back I posted a link to a company that only sells vintage alnico drivers.
Thanks
Actually it is real pine. The sides are average grade 1 X 6 inch, and the front panel is 3/4 inch laminated pine, with a double thickness used on the front, all standard Home Depot wood. I could have
had higher grade pine for $8 more a board on the sides, but went with the standard 1 X 6's. The wood cost me $60. I wanted to match as closely as I could with the
cabinet that my woofer is in. Will post photos when it all gets put together.
The stain I used was Varathane brand, Sedona Red for the bottom coat , and Minwax Ebony on top of that. I will post a photo of what they look like after 7 coats of Minwax wipe on
poly. I just light steel wooled between coats of the poly. On my woofer cabinet, I built it out of that 3/4 inch laminated pine, and lined it with a layer of 3/4 inch MDF.
