Open Baffle Epiphany!
They sure are sensitive. You can hear sound if you just look at the volume control, and I am hearing a lot of detail. They are speakers for finesse and not
for wall banging :)
Yes, I'd guess around 97 dbs and voiced for flea watt tube amps. They're perfect for the kind of music I listen to most which is small group jazz. They've given me a new appreciation for the spit in Miles' trumpet. :D
Thanks for the video on the Alnico vs Ceramic speaker. Subtle, but only because words can only partially describe what our ears can hear :) I enjoy the detail that
the alnico's offer too. I have yet to compare my real Alnico's with the Zenith's, which I have been told are actually ceramic motors, and not the Alnico.
The Zenith's are beginning to open up. At first they seemed a bit brash. I re-mounted my old Alnico's, and they were much more mellow sounding, but in comparison,
veiled, and no where near as much detail. The Alnico's have a stronger lower end which I like, but not the clarity of the Zenith's.The detail was calling me back :) I remounted the Zenith's, and have changed my preamp. Previously, I was using a Superphon Revelation, a transistor solid state.
Now have replaced with another Superphon, but a FET circuit. It is softer sounding, running into a class A Mosfet, a Nelson Pass design. I still have a tube
preamp using 12AU7's to try. The Zenith's do have a much more forward character, but I do like them much more than the Lii Audio F-12's that I tried, which I sent back.
The softer character of the FET circuit has taken the edge off some of the sharpness, still truck loads of detail, yes, I like the detail. Still imagine that it will take some hours to settle the previously dormant Zenith's, but have come more into their camp than I was last night.
in place.JPG Well, I am beginning to take to the Zenith's. They are very revealing of everything upstream. Currently I have ditched my preamp and am using a passive
built with a couple of shunted 10K Goldpoint potentiometers inside, very good quality. Passives can work nicely if you have plenty of signal to work with. Since I am using only 1 amplifier, a re-vamped integrated Scott, just the amp part of it, I am also using a McIntosh MQ-102
that beefs up the lower end at 20 Hz. Since it is tuned specifically at 20 Hz., and rolling off rapidly above 20 Hz, it isn't overloading
the Zenith's. On the top is the upward facing tweeter with a capacitor in line to block the lows. I re-worked the McIntosh with better coupling caps. It brings some foundation and support for my 10 inch Visaton high Qts. woofer that has a coil to roll off the higher frequencies. Since these speakers live in the realm of prowling kitties, everything lives behind a protective screen. I do think that the new baffles for the Zenith's have given the sound a much more open dimension over the old Klipsch cabinets of before with their backs removed.
All in all, I think that the new speakers have gone a step or three in the right direction. When I first heard the Zenith's, I was thinking their purchase was a possible blunder
to satisfy my curiosity, but now I am very happy that I have them. It was a revelation to compare my old Alnico's with the Zenith's and to hear what I had not been hearing.
They are continuing to improve. I am hearing a lot more and it is a pleasure!
What will I do now, just listen:music:
I may explore bi-amping. I have several amps that I can use for the low end, and have my Scott for the Zenith and tweeter.
I guess I am a fiddler at heart, but the sound is much better :)!!!
You can buy a pair of 15 inch Eminence Alphas for not much money. They're probably the most popular OB woofers on the market. Run the Zeniths without restrictions and low pass the Alphas at 70 or 80hz.
I was posting on the Zu thread and it reminded me of the great value we share in DIY open baffle speakers. The new Soul 6 sells for a whopping $6000 yet for the most part its components are off the shelf inexpensive Eminence pro drivers. In DIY one can afford far better drivers and with open baffles you're almost always assured of better sound.
Detractors will say time spent to build speakers is not cost effective. My answer is why would anyone put a price on a hobby which is a labor of love? As if golfers should charge themselves for hours spent on the course. I was happy with my Zu Omens until I discovered I could mount some cheap drivers on a plywood board and get better results. The R&D took about 5 minutes. :biggrin:
Hi Poultry,
One thing I am noticing is a tendency for the Zenith's to beam a bit, sounding more balanced off axis. Do you ever notice that? I don't recall with my other Alnico's or the
Tang Band's, of course the Tang's are 8 inch.
Hi Poultry,
My Zeniths don't beam. With OB's you should be getting as much sound radiation from the back as from the front. One must pull them out into the room away from walls and the further the better. OB's usually have the potential for good off axis response. Depending upon where I'm sitting sometimes I toe in but sometimes I don't.
You know, what I really need is a bigger room, but even in a smallish room, open baffles are a BIG improvement over boxy speakers.
I am still getting accustomed to the added detail and energy in the mid-range. Back in the day when these speakers were in a console, I would imagine that a lot of listening was kind of
off axis. I am wondering if my other Alnico's were not basically woofers because of the pronounced contrast between the upper mid-range output of the Zenith's and the Alnico's. I believe
the added info is what I was calling beaming compared to the off axis frequency response. I could use another 3-5 feet in this room's depth, but even still, I am heading in a better direction
sound-wise than where I was before.
It has been my experience that OB just sound good regardless of the drivers. So long as the drivers measure reasonably well for OB Use. I personally got closer to the music when I pulled them farther into the room
Hi Joespride,
Is that you selling the DAC? I just noticed that you mentioned being disappointed with the Lii Audio F-15's. What was it that you did not like? I had tried the F-12's, and found
them lacking my enthusiasm, but had read some reports from people that love the F-15's. The 12's were hollow sounding to me, very sterile, my disappointment, but glad that
I could return them. The shipping was a chunk of change though!
Hi Joespride,
Its the W-15 I had issues with. At any freq below 40 Hz there was a vibration that was audible in the music from my listening position.
All drivers become more directional as the frequency goes up. When the wavelength is large compared to the cone area the driver radiates omnidirectionally (in a conventional box speaker) or bidirectionally in the case of an OB. When the wavelength is small compared to the cone area the driver radiates over a much narrower angle.
Btw, electric guitarists have known for years that the on-axis sound from a 4x12 cab is very directional, being piercingly sharp on axis and quite dull off axis.
Oh the woofers...It is still good that they have a return policy, but that was an odd quirk for sure.
No they do not have a return policy as such, I have not even seen a warranty. But I would hate to think about shipping 50 pounds of drivers to china. Probably cost almost as much as the drivers them selves. I am not bashing them I do not agree with some of there ways of doing business. They certainly do what is necessary to maintain the upper hand. That does not make them different than other manufacturers BUT when you are dealing with someone in China the shipping or maintenance becomes a real hurdle that IMHO makes the product a bad investment
I've bought more drivers in this hobby than I could say grace over but only had one dud. I called Parts Express to report the dud and they had a replacement on the way by the time I was off the phone. Didn't even ask that I return the defective unit. Now that's great service.
I bought my Em. Alpha 15's from Parts Express 1 driver was damaged by the apes working for the shippers. Parts Express replaced that driver immediately also. I agree they are very good at customer service.
That is a crock! I wonder if they have changed their policy about returns. I recall it was $50 to ship my F-12's to me. It cost me $60 to return them to a warehouse of theirs
out in California. I consider blessed that they agreed to take them back, although when I bought them, it stated on their site that you had a 30 day option to return. Shipping these days
has become the worst part of purchase, but as Poultry said, Parts Express is a top drawer outfit.
Swapped out my 10 inch woofers and went back to my old Alnico's my discovery that they really are not full rangers. They do put out more bass
than the 10 inchers. Guess I will hold up with this arrangement for a spell.old alnico woofer.JPG
I was reading about Lii Audio F-15 in open baffles on the Decware forum and spotted this sentence from Steve Deckert.
"The F-15 is the first driver I have heard that sounds like those old large console woofers".
