That is interesting, breaking new groundHow did you make the round cabinets?
See reply 26 here by joessportster:
https://www.audiocircle.com/index.php?topic=171851.20
Thank you for the linkSee reply 26 here by joessportster:
Using a Dynaco Pas2, with a Volt+D. How's that for an odd combo.
High output impedance preamp with a low input impedance amplifier.![]()
What problem could this create?
Thanks.
There's no problem if it sounds good to you.
Has anyone compared the barrel shaped baffle with one that's rectangular or square shaped? I have a hard time understanding why the barrel shape would be better. Randy at Caintuck Audio originally came up with the barrel shape for the Betsy drivers. I met him years ago at Hornfest where he was using a single Alpha woofer on a flat baffle. That sparked my interest in OB's. He also sells the F-15's in his barrel baffles.
My issue with the barrel shape is that it doesn't place the full range driver at ear level. The back tilt of the Zen barrel might help in this regard.
Randy does this barrel design with the Alpha bass assist.
My issue with the barrel shape is that its almost round and usually has the driver right in the middle, which is the worst possible place as regards edge diffraction. An oblong baffle with the driver at different distances from the top/bottom and sides evens out the diffraction effects. Also, a wider base in contact with the floor extends the LF response as compared to the narrow base of a barrel shape.
