Open Baffle Epiphany!
The finial evolution of the Betsy drivers came when I cut down the folding wing baffle and added the Alphas. I had a pair of Zu Omens at the time and this set up trounced them. The shelf was added to try some Realistic super tweeters.
I like your style, Poultry! With bass augmentation, the Betsy's really shine. I need to get mine back in the alternating line up. I have a baffle designed for them to go in, but have to get them built.
Is that cork on the back of the baffle, and how would you compare the before-cork sound and the after-cork?
Thanks,
Geno
Thanks,
Geno
The cork helps reduce resonance but to be honest unless you listen at extreme SPL's resonance is not an issue. FWIW the cork backing consists of reversed placemats from Ikea. :biggrin:
Happy Easter Poultry :)
Quick question for your sonic memory?
Which sounded more forward in the mid-range, your Zenith, or the Betsy? Which one had better resolution?
Thanks,
Den
Thanks,
Den
It's been awhile for the Betsys but I'd say they were more forward. The Zeniths are really amazing wide band drivers. Love their smoothness and sense of scale. Resolution is very good in both but the Zeniths are at another level with their rich tone and fuller sound. With the Zeniths I can forget to turn on the H-frames and go for a whole session and not even notice the loss of bass.
Found a minty pair of Zenith 49CZ1043's with the Alnico. They look shiny new, and I am looking forward to hearing them paired with my Alnico 12
inch mystery woofers. They look just like the 1064's on the Glow in the Dark Audio site, both being 10 inch smooth cones without whizzer's.
Turn on the H-Frames?
How is your system set up? What does your signal chain look like?
Mine looks like this...
Source > active crossover > amp for highs and amp for lows > speakers
If I did not turn on the amp for the lows, there would be no lows. Very noticeable.
My sources connect to a Bottlehead preamp with two outputs. One output connects to a Bottlehead 2a3 SET amp which powers the Zeniths and tweeters ( the tweeters use caps to block the LF ).
There's nothing in the signal path between SET amp and full range Zeniths to mar the sound.
The second preamp output connects to a plate amp that drives the H-frame woofers. The plate amp has a built in low pass filter. When I've used actives they impart their own sound signature and take
away much of the SET's magic. The best sound I achieve is from full range speakers running full range with nothing in their signal path. The H-frames are brought in to fill in and support the bottom end.
When I use an active crossover with an amp that doesn't have a low pass filter it's only for the woofers and the mains still run full range.
If active xover is between the source and amp and thus not between the amp and full range speaker, how is the active xover inhibiting the SET amp?
It detrimentally affects the signal before the signal is amplified. It's not as noticeable with solid state amps but it's a different story with single ended tube amps.
View attachment 2545259 I have asked this question a few times, and no one seems to want to answer it at all......
How do you guys with open baffle speakers, deal with the Dipole Peaking frequency??
I see no crossover that would actually deal with that.....so??
If you do not realize or know what I am talking about, I can explain it.
https://sites.google.com/site/undefinition/dipole-and-open-baffle/diy-sunflowers
That's an interesting link. Thanks for posting.
There's a school of thought that OB speakers are a panacea and unsurpassed, and that audio nirvana can be had by choosing a suitable driver and mounting it to any baffle. Measurements, physics etc. are pretty much a waste of time and can be ignored. Although I have been impressed with some open baffles, that isn't a school of thought I subscribe to. However, AK does seem to have many subscribers.
Do active preamps and active crossovers do the same thing? Is their circuitry the same?
They both sit between the source and the amp and they both affect the signal before it is amplified.
I was asking how it is that the preamp you use does not alter the signal in a way that is detrimental. And my suggestion was that only a passive preamp would not be detrimental to the signal. Is it incorrect that only a passive preamp would not negatively affect the signal?
Everything that the signal passes through affects it, but a preamp and a crossover have different functions, therefore they affect the signal in different ways.
It is possible that there could be a mismatch between the output level, or maybe even impedience, of a device and the input sensitivity/impedience of the amplifier and the preamp could compensate for this difference improving the sound.
This same question is posed by the author in several Stereophile Magazine preamp reviews and you can read their opinions.
