Open Baffle Epiphany!
Reading the Decware claims for the Lii Audio F-15 in open baffles while I wait on mine to be shipped is quite interesting:
50-17 kHz from one voice coil
100 dbs
Perfect point source
No crossover
No box
No shout
No peaks
Great bass
Not so sure about the last point but bass can be easily augmented. Notice I use the word "augment" which does not mean the same as to replace the bass provided by the F-15. Even a bit of overlap is no big deal.
Steve Deckerts description is that it really “HITS” like a vintage console driver.
Recently got my hands on a couple of new Zenith 1045s. Was thinking of trying them with two alpha 15s per side, as opposed to the H-frames I'm using with my 852s.
Or perhaps one alpha per side and a seperate sub?
For this build I'm considering the Eminence ASD 1000 as well.
Any thoughts or design suggestions?
Thanks
100 dbs
No crossover
No box
No shout
No peaks
Great bass
Poultry,
This is a demo that Steve just posted with these in his large baffles. He is about to release his newly developed 300B amplifier, and is showing it off using the F-15's.
Thanks
You may like the flat baffle double Alphas per side vs the H-frames single Alphas as the sound stage is greater and they're less directional. I now use these flat baffles with an 8" Zenith alnico running full range while the four Alphas are wired in parallel to give a 4 ohm load. The four Alphas are a good choice for a small class D stereo amp as most max power at 4 ohms. An Ashly active is used to filter the HF from the Alphas.
Poultry,
Love the 300B but I wish Steve wouldn't introduce a new amp when the waiting list for the Zen is over a year long.
Ha! I know what you mean. I have a Zen at 634 on the waitlist. Prolly 10 months or so out. This will be my second so that I can run them as fully balanced monoblocs.
Poultry,
Have you ever tried to bevel the back edge of your driver cutouts? I’ve read over and over again, that this can make a big sound improvement. Please excuse me for criticizing, but I just wanted to make sure that you were aware of this - but you obviously have a great deal of experience with open baffles.
Poultry,
I've not tried beveling the rear edge of the cut outs but see it more commonly done on the front baffle. Out of necessity I've used small drivers in large cut outs mounted to a supra baffle which may or may not have made a difference. These 3.5" Coral Holey Baskets sounded great in these OB's with holes cut for 8" Tang Bands but I don't know how they would sound in baffles with the proper cut out.
I always front mount the drivers in OBs rather than recessing them as it puts less strain on the mount which is important if the drivers have heavy motors. If you recess the drivers in 3/4" ply or MDF there's also less material for the screws to bite into.
Video of the Lii Audio F-15s and Fast 8s with augmenting W-15 bass woofer. It's interesting that the two different full range drivers are wired together in parallel with no crossover while the Lii W-15 bass woofer is powered by its own Dayton SD100 plate amp using its adjustable low pass. FWIW my F-15s are due to arrive this week.
Sunday seemed like a good day for organ music so this afternoon I've been enjoying Benjamin Saunders on the organ at Leeds Cathedral. Spectacular with the Zenith's air and wide soundstage.
I have a similar setup, although only one set of full-rangers - with two bass drivers, powered by a Crown sub amp. I’ve been running this setup for several years now, and have not felt the need to change anything.
I rotate between my SET tubes and several SS Sansui amps.
If that's your system I'm impressed.
Genov,
Did your Decware Zen come with the big bottle rectifier tube?
When I got it years back, It came with a bottle shaped Valve Art (labeled 274B) but actually a 5U4G. I was not happy with it. Steve stopped providing it with the amp with initial purchase, not too long after that. I have been using a Russian 5U3C(winged "C") in it for several years, and like it very much.
Some years ago I used a pair of these baffles with two 15" Eminence Alphas. Later I removed the two Alphas, added two more and built the ones shown in my avatar. I brought these down from the attic and plan to try them with the F-15s before I install them on the big flat baffles. They fit nicely on top of the H-frames and the cut out for the Alphas is the same as the F-15s.
Take a look at Steve's video that I posted above. The baffles don't have to be that big, but thickness and a thick base on the bottom helps. And being solidly on the floor too - several of us on the Decware forums use bags of steel shot on the base too.
And you should experiment tilting the baffles back at different angles. This had the most positive impact of anything I've tried.
Steve's Zen Master F-15 baffles are 36" H x 29" W.
Mr Glow-in-the-dark went with 30' H x 28" W.
Mine are 36" H x 30.5" W and have adjustable rear feet which allows for a variety of tilt angles.
With MDF baffles you don't need to go thicker than 3/4 inches unless you play at extreme SPL's. MDF is far more dense than plywood and less resonant. I never play OB's loud enough to excite the baffles. Steve's baffles are solid wood strips glued together. IMO it's a mistake to use solid wood as it cracks and splits over time. Wouldn't last in the high humidity where I live. I like to use the floor for bass bounce rather than an attached base but wonder if the single F-15 is too high in the baffle to make that happen. We'll see.
Steel shot or increased weight helps if you play at higher SPLs.
