That they are. I am interested in how to capture this in photography.Very clean equipment maybe?
100% correct!Studio lighting is one of the primaries for this (on-camera flashes need not apply). Luck has absolutely nothing to do with any fine art photography. Everything is planned, and re-shot based on exposure and compositional experimentation.
Fine equip is a plus but one does not need the latest/greatest.
Stacking/HDR may play a role.
A tripod is mandatory.
Technique is paramount. For flat-field images, understanding diffraction-limited optics and apertures vs. paralleling the sensor with the primary plane of focus is a key.
I have never set foot into a photo studio for shooting- I am an outdoor photographer. All of what I outlined cross over between the two.
Your restriction is not the lens- it's your sensor. Bigger (medium format, or FF 35mm), or higher pixel density sensor. Those images can be had at a 35mm/36MP sensor.100% correct!
I have a Nikon D5200 with the standard lens that came with it. With this lens and using auto settings I cannot get anywhere close to this quality. Ideas?
So the D5200 falls short on the 35mm/36MP sensor.Your restriction is not the lens- it's your sensor. Bigger (medium format, or FF 35mm), or higher pixel density sensor. Those images can be had at a 35mm/36MP sensor.
100% correct!
Absolutely.You did not say what kind of lighting gear you have. You do not need a lot of expensive lighting gear, but you must have some lamps separate from the camera, with some diffusers or reflectors for softer effects (can be made from cheap stuff like a disposable translucent plastic table cloth and white card stock), flags (light blockers) - pieces of cardboard will do, and some clips/clothes pins to hold stuff in place. Doesn't matter if it looks absolutely ratty, it is not in the picture.
First consideration is the setup and lighting. If it doesn't look good to your eye, it won't look good to the camera. Experiment, and be deliberate about the perspective you want. Choose your main light direction, size/distance (hardness/softness) to bring out form and texture. Do not worry about exposure at this point. You will adjust it in the camera. Add a little fill light if the shadows are too dark.
Only then worry about the camera settings to capture the image that you set the lights for, with the desired depth of field.
Worry about exposure last. Do not use automatic settings except as a quick way to determine exposure. The subject isn't going anywhere, so use a tripod and manual camera settings with as small an aperture and slow a shutter as you need, while also using minimum ISO. Still life studio shots often may use shutter settings on the order of one second or longer.
Do any of these hints help?
The application of this is far too limited. It's only good for gear that will fit, and only good if you want heavily diffused light that comes from the particular direction of the provided light strips.Absolutely.
I have been looking on Amazon: Not a clue if this is worth the effort
Travor Photo Studio Light Box 32x32Inch Professional Dimmable Photo Booth Shooting Tent Kit with 126 LED Lights, 4 Backdrops for Jewelry and Large Items Product Photography(13000LM, CRI95+)
I agree. The Auto HDR mode and clean equipment. (may still need to clean up small spots with PS or a similar program) will get you most of the way there. It also helps to have a clean background.Smart phone with decent lighting can get you there now.
In my opinion, any DSLR you happen to have is going to do the job (in manual mode!), the only caveat being that the camera/lens combo can zoom to fill the frame with the scene you want from the point of view (camera position) you want. Unless your goal is to make 20x30 inch prints, anything over 6 megapixels will probably be fine.
100% correct!
I think if I hired a professional to photo my Audio Equipment for sale would be far less expensive:
