Van_Isle
Hmm, i'm not sure on the alignment screw issue. Just going from what Solen told me in their email and online catalog. Anyway I got the pair from ebay anyway.
PE may have the tweeter for $16 but that is a signfiicant difference if you factor in the exchange rate, duty, shipping, etc. vs. purchase from Solen - since I am of course in Canada.
I haven't had the two pair of Titans side-by-side. The 2nd pair is in my office as inspiration to set up a decent system there
But my research definately told me that the stamped steel predated the cast woofers. The cast basket ones also have banana-jack style terminals and the steel basket ones have spring-clip terminals.
The voice coil kit from solen is probably for the version of this tweeter that has alignment screws. Madisound used to have this version. Otherwise, I don't see how you could align the coil in the common D19TD. PE has the whole tweeter for $16, so $11 for the voice coil is not cost effective.
That 2nd pair you got is probably the first version. It should be an inch or so less tall than other Titans. A "shorter" Titan if you will...
