merlynski
Curmudgeon Electronicist
These are not dumb questions! The dbt protects the internal parts of the amp by limiting power to the unit under test, if the amp tries to draw too much power the bulb limits it so no more power can flow through the amp than the bulb would dissipate by itself. As the power supply caps charge at power on the bulb flares bright, but limits the current. When the caps are charged the power draw diminishes and the bulb dims. If the bulb does not dim it indicates that more power is still being drawn. On a large amp a 60 watt bulb may indeed glow after the caps are charged, so increase it to a 100 watt bulb, or more. That one should be dimmer, but still protect the amp. If the bulb does not dim you still have a problem, because a normal amp that is not making music only draws a few watts during idle condition. It only draws large amounts of power when outputting loud music, especially with heavy bass. Think about it like a car engine, when it is idling it only uses a little bit of gas and won't move the car at more than a walk, if at all. When you step on the throttle (turn up the volume) it takes more gas and puts out more power. Even a huge gas guzzler engine does not use much gas at idle, even though it has the potential to put out huge amounts of power at full throttle. The dbt limits the flow of 'gas' so the engine will not over-rev without a proper load. Sorry if that is too much infoIt has not passed the DBT on 150w. The bulb remained bright for about a minute or so and then I turned it off. But since the power consumption of this thing is like hundreds of watts during normal operation (and presumably the current draw is much higher on startup) wouldn't a bulb of like 60w glow regardless? I'm still new to this whole DBT thing so apologies if these are dumb questions.
You can set dc offset on dbt and it will be close to where it should be. You can test the bias on dbt for adjust-ability to check function, but must reduce it to minimum or risk it being to high on full mains voltage. Then set it correctly on full power.
Soft start reduces long term component stresses.
