Pioneer PL-530 Platter removal
persons0
Master of Reality
I picked up a PL-530 this weekend and am trying to figure out how to remove the platter for cleaning. I tried pulling it off but didn't want to force it. Does anyone know how to take it off properly? Thanks
It should just pull off. Try a drop or 2 of penetrating oil on the centre shaft and let it sit and try again if it won't budge. Wipe off the oil afterwards.
I just finished working over a 530, and here are a few helpful hints.
The tonearm mounting body is plastic. Dont torque on it, or apply any force to where it mounts onto the chassis. Mine was totally stripped out at the bushings, reset them with epoxy.
The tone arm lead-in groove stylus positioning screw for auto mode is in the hole to the left of the tonearm body pivot. Helpful for fine tuning.
There is a muting circuit that is cam driven off the separate tonearm motor. It operates a set of reed switches underneath the deck, so there is no groove noise when the stylus lifts off the record.
Mine had dirty contacts, so gave me the dickens trying to find the source of intermittent left channel cutout. Finally figured it out, and cleaned the points with emery paper.
All good now!
:banana:
