Sky blue SANYO caps are usually very small ones, definitely not 100uf or 330uf. Use UPW's. I ran the parts list, no low leakage 100 or 330's called for.
Lots of the large light blue caps on your pictures are mainly nichicons.
Using ukl's instead of upw's won't hurt anything (except your wallet a bit).
Panasonic low leakage electrolytics? I don't think they exist, but would welcome finding out to the contrary.
aligning neutral potential - just turn the volume down to zero. no resistors needed - just some obsessive perfectionists over thinking the plumbing.
BTW, that is supposed to be a 4.7 KILOHM (4700 ohms) resistor - and the wattage is nil, so 1/4 watt would do.
these:
2SB530 pnp
2SD370 npn
are your power output transistors. TO-3 110v 8a 80w
use:
........534-4662 to-3 mica insulators $0.16 each.................
863-MJ21193G pnp to-3 250v 16/30A 250W 8-75hfe 4mhz $4.07
863-MJ21194G npn to-3 250v 16/30A 250W 8-75hfe 4mhz $4.07
look forward to seeing the lists online!!
(please don't pull the trigger on parts before that, and if you use the format:
awr-216 C21 470 10 cea
awr-216 C22 220 16 cea
awr-216 C23 10 63 cea
awr-216 D6 KZL-140
awr-216 D13 MZ-110
awr-216 Q1 2SK34
awr-216 Q2 2SK34
of
board number, part location, uf, volts, etc
it will be a very enduring list.
