OK so I think this is much neater than before, I know iylts not as neat as you guys do it but hopefully it passes muster
Not neat? I haven't seen anyone else use hex bolts before!
In fact, those F&T caps are pretty good and reliable. I'm sure they're up to their spec already. Did you measure them?
Looking good, I know those terminals and the small leads can be tricky - get real hot when soldering too.
I wonder if that bleeder resistor is too close to the film cap? I similarly did like the above on my 950 and after running it a bit I realized that the bleeder ran pretty hot.
I only replaced the caps on that board as there wasn't an issue with how it is functioning.
I wouldn’t bother changing the 2SC1318.
I'm just looking at this thread, and notice the AWH-032-O amplifier boards, and the German electrolytic caps in your power supply, I have never seen this before in an SX-1010 (and my first one was a multi-volt also). Most common is the A board, and I've owned D (the latest), yours was sold Sep 1974 so a fairly early unit, I wonder what else is unique?
I've seen some stuff that had been done by long time tech's that didn't look 1/4 as good. VERY NICE!
Idle current will vary depending on what's put thru it. Make sure the selector switch is set to "AUX", Volume all the way down, and all other tone controls are centered when testing or setting the idle current and the center voltage. A couple mv one way or the other isn't going to hurt anything. However it shold be stable within a couple mv of your setting + / -.
Wow! That power supply board is sweet. Does Zebulon sell them or did he provide instructions and list to create?
