Ok so i have encountered a problem with the LED fitting - I installed bulbs one by one, testing with dbt in between each bulb, so got all speaker select bulbs in, the high, low filter and -20db as well as all source lights, all tested ok, only have the loudness and mono bulb left.
Now for some reason, after securing the board back onto the chassis via the 2 screws, all source, muting and high low filter, mono and loudness LEDs are not working, unit passes DBT and all LEDs i installed did work prior to this, no fuses are blown, checked with meter out of circuit
Not sure what exactly to start with, pin voltages? If so what pins are we looking at?
AWS-068 Pins 1 through 7? Visually everything looks good.
Dammit, was so close to a good run with no major errors afraid to to anything else without your guidance on this,
@zebulon1 @merlynski @larryderouin apologies for calling on you all, hope you can help me out here, thanks
Very strange, it has to be a dodgy connection, these boards have lots of pins and are pretty tight to access. I will try investigate with unit off and see if i can see anything amiss
Dimmer switch has been cleaned and FM muting switch also
