For what it's worth, here is a consideration:IME computer back up power supplies tend to produce lots of noise on the AC output. While they will allow safe shutdown when AC is lost, I'd use them only with appropriate caution. Attach a scope probe to the AC out of an APC and observe the noise for yourself.
FWIW: I use a Tripp Lite Isobar on a dedicated 20A line for my small signal sources. My power amplifiers are on their own dedicated 20A lines (2).
I have noted that some prefer using Power Conditioners/Surge Suppressors for their audio equipment. It would be less expensive and beneficial to have a SPD installed at the main panel to protect the whole house (including dedicated circuits). The latest electrical Code (NFPA 70 - NEC - 2023) now has 4 types of Surge Protection Devices (Type 2 - protection at the Service entrance as being the least expensive to retrofit).
Ballpark cost - $80 for a good SPD and breaker pair and $150 for an electrician to install it.
For an audio-visual on what it takes to install an SPD and what are the different types of SPDs, see
Note: Although the video only explains Types 1 through 3, Type 4 is what is installed intrinsic to and integral with equipment.
I am in no way affiliated with any electrical contractor or manufacturer/dealer/distributor/reseller of SPDs.
Sincerely,
John Graham.
