Now back to our regularly scheduled program, lest I be accused fairly of hijacking the thread. I discovered computer UPSs as a solution in part to a problem we wrestled with for years in my current home. Every time there would be a thunderstorm, a spike would come into the house and wipe out a piece of equipment or sometimes a lot more. additionally, there was often an accompanying power outage. I had several computers at the time each running some version of windows and given the reliability or lack thereof I often had to reinstall windows because of what happened from a random shutdown. At the time we were using DSL from verizon for internet service and so we had a standard land line connected to verizon and of course a power connection to Appalachian Power. Due to the transient nature of lightning surges it was difficult to isolate where the surges were coming from. Our initial thoughts were from the power line and so we started trying to protect equipment via UPS. As the years went by, we came to realize that the problem was not the power company but the phone company. The final piece in solving the mystery of the source of our ongoing equipment loss came one day when we had an electrical storm very close by and when the spike came thru on the phone line it was sufficient in magnitude to completely explode two DSL filters. These filters were a clamshell plastic housing with a small circuit board inside, one 1/2 of the clamshell had been blown completely across the room, and none of the components on the now exposed circuit board could be identified due to the high current thru the device. In that one event we lost the DSL modem, two dsl filters, two computers, a cat 5 router and a tv.
At that point it was obvious beyond any doubt what the source of the trouble was and that was the day I went totally wireless. I lost a few routers after that but never again did a computer bite the dust. The ups kept the power on long enough to do a proper shutdown thus avoiding OS corruption and the wireless router kept the incoming spikes out of the computers. Naturally I had kept track of all the equipment lost over the years by keeping each piece that was fried. I called verizon out on a service call, they knew me by first name due to our many encounters and flat out told me they were not responsible for all the equipment connected and lost to their faulty service. It amounted to well over $10,000 worth that had been ruined. It was at that moment I declared war on Verizon and their shoddy service. It was about 18 months later I found an alternate source for my internet and had acceptable but poor cellphone service and I dropped em like a hot potato.
When I received my house`s lightning strike in 1997, I was using a dedicated (separate from the original land line) dialup land line feeding my expensive because of the high amount of memory for that era.
That computer dialup only phone line fed by me into this room where the computer resided straight from the outside phone box into a Panamax "All Path" modular based power/telephone (RJ-11 surge/spike protector that I purchased from Crutchfield at the time I had the computer built for me in 1995.
The lightning strike hit a ~30 ft. in elevation VHF/UHF scanner antenna on the same side of my house where all (power. both telco lines) my outside drop wires fed into my house.
The intensity of that EMP from the strike ~15 ft. from the elevated phone lines destroyed the telephone companies dialup line`s outside interface box surge/spike protector, but not the regular phone line protector located in the same box.
The computer was on and connected on line at that moment, but suffered zero power supply damage to it, it`s dialup modem, the HQ NEC monitor connected to it!
That was the second Panamax surge/spike protector purchased by me since 1991 when the A/V installers were installing my Barco brand very HQ projector, strongly encouraged me to purchase and have them connect it to the Barco`s dedicated circuit input power to the $9,000 three tube projector.
I`m a big fan of Panamax, and Tripp-Lite power and signal cable`s surge/spike protectors, as they have both been subjected to countless intense surges/spikes since installation from both manmade and lightning based events with only cheap SMPS wall wart failures.
I learned a strong lesson from that 1996 lightning strike event, that "every single signal type wire/cable" brought from outside into my house, and also those audio and video signals distributed in the attic from my living rooms master source A/V rack to the house`s other room`s A/V systems has to have surge/spike protectors at both ends, or like you experienced, lightning`s destructive energy will destroy everything in its path surging through the wires looking for ground from a direct or nearby lightning strike`s EMP!
IMO/E, Well worth every dollar spent and effort to implement, so I can continue to enjoy my A/V equipment instead of trying to repair or replace them after a intense surge/spike "event"!
