Something worth knowing about Holman pre-amps.
The input selector switch is or can be persnickety. Despite using contact cleaner, a channel could likely disappear from time to time. I have two of those units and each one. exhibits that anomaly. In the case of mine, it’s been on both phono 1 and phono 2 inputs.
The first pre I got began producing spurious noise a couple of weeks after my doing a fair bit of parts replacement including all 41 electrolytics. Not being able to find fault with any transistors, my most suspected culprit, I sent it to Audio Proz. The cause was actually two of the four op-amps.
The preamp came back with a note saying they cleaned all the switch contacts but that I should exercise them frequently. That proved to be excellent advice.
Now, even if only 24 hours have passed since last listened through, I rotate the input selector end to end about 15 times before playback of anything.
I’m very fond of APT Holmans. They sound wonderful and are geared towards turntable enthusiasts. I consider the extra step of input selector exercise just a cost of owning/using a great audio component.
Sold one long ago for the same reason ..
