That sounds convincing... As far as I read through many reviews regarding EL84 amps, reviewers mentioned their "Life-like" sound signature. I did quick research for ST-35, then only the positive reviews I could found. Only the thing hooked me was that someone said ST-35 was the warmest sounding in his shootout with several EL84 amps. Do you agree with his statement?
The Cary six pack is basically half of my Cary V12's, The six pacs are a pair of amps, one amp for each channel, mono blocks with 6 EL34's per amp which are PP, so you get the tube that many seems to rave over, and it puts out 50 watts per channel, so your choice of speakers are less limited. But you can run 6550, KT66, and KT88, tubes as well, which other people seem to like as well. This amp was designed by Dennis Had, well known for making some great sounding amps, and although I don't own the little six packs, I do own the big version which are v12 mono blocks, 12 EL34's per amp switchable on the fly to either triode, or Ultra linear on each pair of tubes so any combination of pairs. I can say it is a very good sounding amp, just as the smaller 6 packs would be. Then paired with a Dennis Had, SLP 98, you would have a very good system. I have a Cary 98 as well, with the ultimate option upgrade, but even the basic model 98 is a top-notch preamp, with remote power supply. And the tubes are all on top exposed, so tube rolling is a snap. It uses the 6sn7 tube, which are very common and still somewhat reasonable, a tube I personally really like.Totally. I am always eager to go with separates if budget allowed, and your suggestion is very attractive for me. How would you describe the sound of its combo? just briefly.
I also have a pair of the Altec Flamenco's, I pair them with my 300b amp.I'm always on a budget and I've been a working musician for over 50 years. So take my advice with a grain of salt please.
I always prefer push pull el84s and an st35 is my favorite with the right preamp. Having said that I just finished a pioneer er420 receiver with el84s in the outputs and it sounds amazing with Lps. However speaker choice is critical. I use Altec flamencos, tannoy 15" dual concentrics or EV marquis with coaxial 12" ev drivers. All of these have terrific efficiency and really nice dynamics.
That's my 2 cents.
If I could find a great EL84 SEP that is under that wattage limit I would love to give it a shot,
Yup. I added a volume control to the EL84 console amp I modified to run stand alone along with my VTA ST-70. All that's needed is an input selector if you have multiple sources. There are also volume control/input selector boxes. Some of my smaller systems don't have a preamp at all, just a volume control and maybe an input selector.Remember that you can just use a single pot to control an EL84 power amp.
Luckily, I do have several hobbies that loves to suck up the numbers out of my bank account. Thus, OTO is like a gorgeous lily flower blooming on top of the cliff.Yes, the OTO is pricey, isn't it?
Have you considered a kit? The Bottlehead Kaiju is quite a nice amplifier and their kits are very well put together. Pair it with their inexpensive preamp kit and you'd have a very nice system.
OTOH, the nice thing about PP EL84 is you get a lot of midrange magic of single-ended, with better frequency extension and control.
Wow, great write up Ken! I do not see anybody who criticizes his amps, never. Dennis' 300b must be one of the ultimate 300b SET I believe. Anyway, thanks for sharing your detailed, insightful thoughts! My R300 sounds warm dark and soft, and this gives me a certain feeling, "OH, sounds comfortable but not correct..."The Cary six pack is basically half of my Cary V12's, The six pacs are a pair of amps, one amp for each channel, mono blocks with 6 EL34's per amp which are PP, so you get the tube that many seems to rave over, and it puts out 50 watts per channel, so your choice of speakers are less limited. But you can run 6550, KT66, and KT88, tubes as well, which other people seem to like as well. This amp was designed by Dennis Had, well known for making some great sounding amps, and although I don't own the little six packs, I do own the big version which are v12 mono blocks, 12 EL34's per amp switchable on the fly to either triode, or Ultra linear on each pair of tubes so any combination of pairs. I can say it is a very good sounding amp, just as the smaller 6 packs would be. Then paired with a Dennis Had, SLP 98, you would have a very good system. I have a Cary 98 as well, with the ultimate option upgrade, but even the basic model 98 is a top-notch preamp, with remote power supply. And the tubes are all on top exposed, so tube rolling is a snap. It uses the 6sn7 tube, which are very common and still somewhat reasonable, a tube I personally really like.
I was a bit concerned for a while with my amps seemingly low volume, but with the Cary pre that is no longer an issue. and the preamp, really for many would be an end all preamp, it really is that good.
As for warm, I think of that as a strange why to describe music, my amps are very dynamic, and effortless on reproducing big symphonies, to heavy metal, and yet on intimate performances with small groups or solos, from opera, to jazz, it is really lifelike and revealing. They produce deep bass, while have plenty of sparkle on top, with a really live like midrange. I won't say I am very good at being an author, and putting things to pin, but it is not hard to do a goggle search on the items, so others can do a better job at reviewing, I am a technician, not a reviewer.
Spooky real!!! Oh my goodness... I desire to say so.I think you have gotten a lot of good advice here. My setup sounds spooky realistic with the right music. Speakers are EV Aristocrats, one with a 12TRXB, one with an SP12B + T35 combo.
My amp is a fully upgraded Elekit TU-8200R, Lundahl transformer and Mundorf Silver Gold coupling caps. Tubes, which are one of the reason is sounds so good, are NOS RCA JAN 6189 and original Genelex KT88 running ultralinear. I also have a pair of matched RCA clack plate 6L6GC. They sound really, really good, but not as good as the KT88s. I think the KT88s easily match the mids from the RCAs, but blow them away on the highs and lows.
If you are up for a kit, I highly recommend an Elekit, purchased from Victor Kung (vkmusic). As soon as I sell my Marantz separates, I am going to buy an Elekit TU-8550 preamp kit to go with it.
Well, I overlooked this info. Thanks. So the AudioNote OTO SE must be PSEP...FWIW
A single ended pentode EL84 is going to be somewhere around 3 to 5 watts.
Thank you for telling your thoughts. Yes I would update once I decide. Enjoy music!I am a newbie to the tube world and have been lurking around gathering information from those who have lived it for decades. I started with a restored Scott 222C, then a restored 299C. They both sounded very nice, but decided to go with something new for reliability. Auditioned the Rogue Audio Cronus Magnum III; thought that was going to be the one. Went with an Erhard Audio Aretha MKII preamp and a new ST-70 with all the upgrades from Getdynaco.com. The clarity, sound stage, and overall presence is an absolute joy. I am still tracking down a ground loop, but it is much quieter than when I first put these two together. Good luck with your quest and keep us updated on what configuration you end up with.
For me, all I built so far, 6AS7G, EL84, EL34, 6BG6, 6A3 but F2a tops all. Built three of them, all dual monoblock plus fourth around RS1003 for a friend. Fifth RS1003, tube rectified is planned around permalloy iron.
Yup. They can sound good though. But not a lot of wattage coming out of one. Only 3.5wpc. I have some woofers and horns out of an old console that would probably go well with the EL84 SE amp I built. They're pretty efficient.FWIW
