Order placed, $160 - Thanks for the BOM. Really wanted to use the Nichicon Gold filter caps but they were $25 a pop! MJE15032G is OOS at Mouser - Digikey has em. Probably will need a second order with this so I will wait until I get further along and realize I need something else.
Thanks for the BOM - Well documented/detailed. I noticed you updated your PDF/Word doc with the "updated" Power Supply etc changes after the first attempt correct?
Here is what I gathered, anything bold is my modification due to stock/voltage bump due to same size. Note can't guarntee its perfect, some of the cheapie $0.10 items have some extras included.
Filter: 4x ALT22A153DE063
4x: ECW-FE2W225J
F-2721 (Amp Driver Circuit Board) Right / Left Total (2) Double Below
D01-D04 – 1S2473 / Now 1N4148
ZD01-ZD02 – EQB01-22, 22v 1-Watt Zener Diode / Now 22v 1.3-Watt (BZX85B22-TR)
C02; C04 – Original 33uF 25v / Now 100uF 35v (Nichicon UPW1V101MPD)
C12 – Original 1uF 50v / Now 1uF 63v (WIMA MKS2C041001F00JA00)
C11 & C14 – Original 470uF 63v / Now 1000uF 63v (Nichicon UPW1J102MHD)
R15 – Original 10k Ohm ¼-Watt / Now 10k ½-Watt MBB02070C1002FC1 (1% Metal Film)
R16 – Original 27K Ohm 1/4 -Watt Carbon Resistor / Now 27K Ohm 1/4-Watt Metal Film (KOA Speer MF1/4DC2702F)
R23 & R25 – Original 150 Ohm Fusistor / Now 150 Ohm 1/4-Watt Metal Film (1% KOA Speer MF1/4DCT52A1500F)
TR01-TR02 – Original 2SC1400 ECB / Now KSC1845F (HFE Matched)
TR03-TR04 – Original 2SA750 (PNP) ECB / Now KSA992FB
TR05 & TR11 – Original 2SA899 / Now KSA1220AYS
TR06 & TR09 – Original 2SC945 / Now KSC945CY
TR07-TR08 – Original 2SC1904 / Now KSC2690AYS
TR12 – Original 2SD382 / Now MJE15032G
TR13 – Original 2SB537 / Now MJE15033G
VR1 – Original 100 Ohm Trim Resistor / Now 100 Ohm Single Turn Sealed 3/8” (Bourns 3386H-1-101LF)
VR2 – Original 2.2K Ohm Trim Resistor / Now 2.2K Ohm Single Turn Sealed 3/8” (Bourns 3386H-1-222LF)
VR3 – Original 1K Ohm Trim Resistor / Now 1K Ohm Single Turn Sealed 3/8” (Bourns 3386X-1-102LF)
4x Output transistor Micas 534-4636
F-2263 – Power Supply
C05-C08 – Original 220uF 63v / Now 820uF 63v (Nichicon UPW1J821MHD)
C09, C10, C11, C12 – Original 100uf 63v / Now 330uf 63v (Nichicon UPW1J331MHD)
C17-C18 – Original 470uF 16v / Now 470uf 25v (Nichicon UPW1E471MPD)
C19-C22 – Original .47uf 50v (LL) / Now .47uf 100v (WIMA MKS2D034701E00KSSD)
C23-C26 – Original 100uF/35v / Now 220uF 50v (Nichicon UPW1H221MPD)
C701- C704 – Original 15000uf 63v / Now 15000uF 63v KEMIT ALT22A153DE063 (85C 26k Hour)
C707- C710 – Bypass Caps Polyester Film 2.2uf 100v / New 2.2 uF 450v Polypropylene Film (Panasonic ECW-FE2W225J)
R7, R8, R9, R10, R11, R12, R13, R14 – Original 10k Ohm ¼-Watt / Now 10k ½-Watt 594-MBB02070C1002FC1 (1% Metal Film)
R33-R34 – Original 22k ¼-Watt / Now 22K ½ Watt 594-MBB02070C2202FCT (1% Metal Film)
D05-D12 – 10D2 1-Amp Diode / Now MUR220RLG, 2A / 200V Ultrafast Diode
D13-D18 – 1S2473D & 1S1588 Diode / Now 1N4148
D601 – D602, 10D2, 1-Amp Diode / Now MUR220RLG, 2A / 200V Ultrafast Diode
D603 – 1S2473D & 1S1588 Diode / Now 1N4148
D604 – VD1212 Varistor / Now Double (Series) 1N4148 Diodes
D605-D607 – 1S2473D Diode / Now 1N4148
D608 - Diode, 1A/100v, 10D1 (1S2226)): /1N4004T 1A/400V
D609-610 - VD1212 Varistor / Now Double (Series) 1N4148 Diodes
ZD01-ZD02 – RD13E (B) 13 V, ½ Watt, Zener / 13W, ½-Watt, Zener, 1N5243B
ZD601 – EQA01-06R, 5.6V, ½ Watt, Zener / 5.6W, ½-Watt, Zener, 1N5232B
ZD602 – RD13E Zener 6.2V, ½ Watt, Zener / 6.2W, ½-Watt, Zener, 1N5234C
TR01-TR2 – 2SD356 / Now MJE15032G
TR03-TR04 – 2SB526 / Now MJE15033G
TR05-TR06 & TR09-10 – 2SC1708 / Now KSC1845FB
TR07-TR08 & TR11-12 – 2SA847 / Now KSA992FB
TR601-TR603 & TR605-607 – 2SC945 / Now KSC945CY
TR604 – 2SA733 / Now KSA733CY
C601 – Original 47uF 50v / Now 100uf 63uF (Nichicon UPW1J101MPD)
C604 – Original 470µF 10V / Now 470uF 25v (Nichicon UPW1E471MPD)
C605 – Original 33uF 50v / Now 47uF 63v (Nichicon 647-UPW1J470MPD)
C606-C607 – Original 4.7µF 50V / Now 4.7uF 63v (Nichicon 647-UPW1J4R7MDD)
C29-C30 – Original 220µF 6.3V (bipolar) / Now 220uf 25v (Nichicon 647-UES1E221MHM)
Relay = Omron MY2-02-DC24
F-2720 –Tone Control
C05-C06 - Original 0.33uF Polyester Film / Now .33uF 450v Polypropylene Film Panasonic ECW-FE2W334J (5%)
C07-C08 – Listed 10pF Found 22pF Ceramic / Now 22pF 100v (C0G) RDE5C2A220J0M1H3A (5%)
C15-C16 – Original 10uF 16v / 10uF 35v (Nichicon 647-UKL1V100KDD1TA)
C21-C22 – Original 10uF 16v (signal) / 10uF /35v (Nichicon 647-UKL1V100KDD1TA) LeeStereo- Ben Prefers UES Here
C23-C24 – Original Listed 10pF Found 22pF / Now 22pf 100v (C0G) 5% RDE5C2A220J0M1H3A
C25-C26 – Original 0.47uF Polyester Film / Now to 0.47uF 250v Polypropylene Film WIMA MKP4F034704D00JB (5%)
C27+C29 & C28+C30 – Original 100uF 6.3v Polar In Series for Bi-Polar Configuration / Now Single 47uf 16v Nichicon UES1C470MPM (Bi-Polar)
C31 & C32 – Original .1 uF Film (bypass) / Removed
C33/C35 & C34/36 – Originally 4.7uF 50v (LL) in Series for Bi-Polar / Now Single 2.2 uF 450v Polypropylene Film Panasonic ECW-FE2W225J (5%)
C39-C42 – Original 47uF 50v / Now 220uF 50v (Nichicon UPW1H221MPD)
C45-C46 – Original 10uF 25v (LL) / 10uF /35v (Nichicon 647-UKL1V100KDD1TA)
D01-D02 – Original VD1212 Varistor / Now Double (Series) 1N4148 Diodes
R37-R40 – Original 82ohm ¼ Watt Fusitor / Now 82ohm ¼ Watt Metal Film KOA = MF1/4DCT52R82R0F (1%)
TR01-TR06 – Original 2SA726 (PNP) ECB / Now 512-KSA992FBU (HFE Match) TR1/TR5 & TR2/TR6
TR09-TR12 – Original 2SC1400 ECB / Now 512-KSC1845FTA
TR07-TR8, TR13-TR14 – Original 2SA750 (PNP) ECB / Now KSA992FB
F-2670 – Pre-Amp Switch Board
C01 - C04 – Originally 10uf 25v (polar caps in series for bipolar) / New 2.2 uF 450v Polypropylene Film (Panasonic ECW-FE2W225J)
ECW-FE2W225J | 2
F-2723 – Tone Control Board
C01-C02 – Original 1uF Polyester Film / Now 1uF 450v Polypropylene Film TDK B32672Z4105J00 (5%)
C03-C04 – Original 100pF Ceramic / Now 100 pF 100v Polypropylene Film WIMA FKP2D001001D00JO00 (5%)
C05-C06 – Original 220uF 6.3v / Now 470uf 25v Nichicon 647-UES1E471MHM (Leestero prefers Bi-Polar Here)
C19-C20 – Original 10uF 16v / Now 10uF 35v (Nichicon UKT1V100MDD)
C27+C29 & C28+C30 – Original 10uF/25V (LL) in Series / Now 4.7uf 63v Stack Polyester Film WIMA MKS2C044701M00JO00 (5%)
C31-C34 – Original 10uf 50v / Now 47uf 63v (Nichicon UPW1J470MPD)
D01-D04 – Original VD1212 Varistor / Now Double (Series) 1N4148 Diodes
R47-R50 – Original 82ohm ¼ Watt Fusitor / Now 82ohm ¼ Watt Metal Film KOA = MF1/4DCT52R82R0F (1%)
TR01-TR02, TR05-TR06 – Original 2SA906 (PNP) BCE / Now KSA992FB (HFE Match) TR1/TR5 & TR2/TR6
TR03-TR04 – Original 2SA726 (PNP) ECB / Now KSA992FB
TR09-TR10, TR15, TR16 – Original 2SA750 (PNP) ECB / Now KSA992FB
TR07-TR8, TR11-TR14 – Original 2SC1400 ECB / Now KSC1845F
BOM:
512-1N4148| 35
BZX85B22-TR | 4
UPW1V101MPD | 4
MKS2C041001F00JA00 | 2
UPW1J102MHD | 4
594-MBB02070C1002FC1 | 11
MF1/4DC2702F | 2
MF1/4DCT52A1500F | 4
512-KSC1845FTA | 19
512-KSA992FBU | 100
512-KSA1220AYS | 4
512-KSC945CYTA | 11
512-KSC2690AYS | 4
MJE15033G | 2
3386H-1-101LF | 2
3386H-1-222LF | 2
3386X-1-102LF | 2
534-4636 | 8
UPW1J821MHD | 2
UPW1J331MHD | 4
UPW1E471MPD | 3
MKS2D034701E00KSSD | 2
UPW1H221MPD | 6
667-ECW-FE2W225J | 12
594-MBB02070C2202FCT | 2
863-MUR220RLG | 5
621-1N4004 | 2
512-1N5243B | 3
512-1N5232B | 2
512-1N5234C | 2
512-KSA733CYTA | 1
UPW1J101MPD | 1
647-UPW1J470MPD | 5
647-UPW1J4R7MDD | 2
647-UES1E221MHM | 2
MY2-02-DC24 | 1
ECW-FE2W334J | 2
RDE5C2A220J0M1H3A | 4
UKL1V100KDDANA | 6
MKP4F034704D00JB | 2
UES1C470MPM | 4
MF1/4DCT52R82R0F | 8
B32672Z4105J000 | 2
FKP2D001001D00JO00 | 2
647-UES1E471MHM | 2
UKT1V100MDD | 2
MKS2C044701M00JO00 | 2
Out of Stock
MJE15032G | 2
