No, and why can't some mfg just make an IEC with a round chassis and be done with it? Sonsabitches.
I second that:yes: But I'm thinkin' that the CNC tooling for a square hole can make different size holes,offsets,notches,and the like.A circle gets used for that size circle only-so they don't bother.During assembly the square peg fits in the square hole.("do you want fries with that?" comes to mind)Maybe cheaper to make,too. I guess it's the standard now.:thumbsdn: Then again,I see a few high - dollar IEC connectors and cheap ones.Nothing in the say,4 to 15 dollar range.I bet some money could be made with a medium quality one that fits the standard square hole,and comes with an indexed sleeve to fit a standard round knock-out punch size.No, and why can't some mfg just make an IEC with a round chassis and be done with it? Sonsabitches.
:scratch2:...we have a plastics place here(Hopkins)that makes everything from icescrapers to headlight aiming devices.Bet they could come up with a 39 cent sleeve-the tooling and molds would run a couple grand,though:tears:Terry, I like the sleeve idea, very interesting.
How about this- A round cylinder with an 1/8" thick flange.The IEC ears bolt thru the flange,and thru the chassis.This cylinder has a rectangular hole for the smallest size panel mount IEC connector you can find.It only needs to be maybe 5/8" in overall length. You could even mill out a "step" inside the rectangular hole for a slightly larger body.The end user fits the connector to the adapter with a file or dremel,punches a hole(or use a stepped bit),and drills the flange and chassis for screws. No, and why can't some mfg just make an IEC with a round chassis and be done with it? Sonsabitches.
