Correct, for instance depending on the maker just for one style of IEC-320 C14 connector there is up to 3.5mm variance in the height of the cutout (I found 16.5mm on the small end and 20mm was typically the largest) and somewhat less for variance in width, call it 27mm - 27.5mm.
That was learned from auditing the various makes of "standard" front screw-mount IEC C14 power inlets with the flanges on the side, which are pretty typical. The version with flanges top and bottom may have different dimensions, and if they rear mount the dimensions increase.
This came up in the process of researching a replacement part for the old C10 2-pin socket as used on much of the Tandberg 3000-series gear. They moved to the C14 3-pin later (probably required by changes in electrical standards) but the cutout doesn't appear to have changed. The 2-pin version is pretty scarce these days so I was looking for a 3-pin that fit the cutout, so as to avoid having to file out the rear panel cutout. May have found one, but I won't know until I get it and try fitting to an older 3-pin unit.
John
