They sound, man they sound.
There have a distinct sound in between the cassette and the 3.75ips 4 track RTR.
Quite no hiss, people say there is a lot but the spectrum analyser is against them!!!
With a good serviced deck and blank tape you can make really good sounding tape! (50hz-16Khz Flat)
This said the system precision is not the most accurate, you can have cross talk misalignment just by moving the cartridge. (the best is to insert the cartridge let the player set it and don't touch it)
Also the old prerecorded tape quality is like pre-recorded cassette, not the best you can achieve.
Plus yes it's but i must be wrong quite impossible to keep them in excellent shape for 60 years, the glue in the track switch leader will goes out someday making the tape in best case just going out of the cartridge and in the worth case some few seconds ruined by the capstan.
That's certainly also the case for blank tape.
However tape isn't also known to last so long without issues.
Also well you need fast access to the mechanism in case of trouble, or just for cleaning and demag, so if you don't modify the case, it's nude use most of the time because like a RTR, cassette deck or whatsoever tape base constant cleaning is necessary especially when you use it for hours and hours and you will!
Wow and flutter case, well i have very old tape with inaudible, and other with audible, specs aren't bad, so i suppose it's tape keeping dependant!
In fact this support need supports, new tape to refills cartridge with.
The tape jam, isn't really an issue as it would occurs in case of new tape well above a descent time usage. Unless you play football with it.
I love them:
- Just as easy as push to play, you enter them with feet or eye closed!
- The sound is unique and very acceptable, especially with blank tape and why note a good dolby B bias optimized.
- The program selector and the FF button help correcting the lack of the RW button. Again if you'r not the man which absolutely want to be a that track from the start, you will more enjoy the fast program change which make things like radio. (I love this)
The correct use for very demanding people is program change ff to finish current track.
- They can run all the day with the same cartridge.
- You can just make a pills of tape you like and play them it eject at each program or end of the tape, or can repeat program, while you're working, instead of constantly hearing this digital sound which is full of phase distortion and no good for easy long time listening!
- Analog device to cherish, push /button/knobs, cleaning, in worth case tape cartridge repair, time to make a recording, all analog sane activities whose will take you off the digital screen!
Sometimes i'm dreaming of a dolby C HX room three head player/recorder with fine bias and rec level and a serious drawer (where the cartridge can't move at all), just would explode the cassette and 3.75IPS 4 Track but as already said the sound capabilities on home player/recorder is really descent. (in fact i think it's better than a type I cassette with no/B dolby and no hx room)
F... give me new tape with back graphite in order to enjoy this underrated for the time, and very welcome today as something else than virtual format at it's most... those old tape are getting older and older, to much repaired and with old content...
And no, even the LPR35, with it's special back coat won't work flawlessly, perhaps i did put to much 80mn but the sound recorded with this tape...
