Tell me that the sound is awful again, you bad faith.
Despite again issue with the cartridge and/or moving head precision, it sound good, not audiophile, but much descent for background listening, and that's all we want instead of digital which sucks by any way!
"digital get away parenthesis"
I spend my days listening/analysing digital, it sucks, cd is the worst format ever produced commercially.
When you get higher 192Khz-768Khz it start to be better, but still the mid are grainy, and the high are just distortion.
People thinks because it's agressive, loud, harsh, it's better! They are totally false.
Just try to listen 4 Hours of digital, then the next 4Hours of a good RTR 7.5IPS 4 track, without any pause after this switch back to digital , you won't stay 10s.
People have most of the time are underrating the inexistent audio memory and do not know how to compare things, nor have most of the analog support to do it!
Just generate a sin wave and play with it from 1Khz to 22Khz!
You won't believe how much phase distortion it got and very much audible even at 192Khz!
Try it below 44Khz, ex: 22Khz it's just a whole new sound even if in the frequency range!!!
No digital sucks for sure, even mastering engineers know this, but again it's as bad as convenient.
People by def are lazy and choose the most convenient and cheaper over the best quality and pricey!
But when you're stuck with only digital sound to feed you ears for years, i can assure you than even a 8 track will be heaven!
Of course you can spent 100000$ to get a descent sound, but i don't think it's wise, and anyway better, as the digital is corrupted at it's almost base, the data.
A test that everyone can do easily it to put a vinyl record or whatever analog source in direct onto the sound card, record a passage min 192Khz, and listen it back, it's incredible the sound has changed in worst forever.
I've learned it from burnie, when i leaned that, i found that just impossible, but he was so right!
"digital get away end of parenthesis"
By the way the moving mechanism can suffer misalignment cause car vibration, certainly that's why the azimuth knob was present in most car player.
However in home use, the issue is unlikely!
The convenience is at most in this one!
The 4 track cartridge were better but not as convenience.
Yeah i agree most pre-recorded tape needs:
+20db for 16hz-32hz-?64hz? still not sure how much for this one
+20db from 8Khz-16Khz-32Khz
Sound excellent like this!
On New Recorded tape, just a little boost below 50Hz.
Regarding the loss of high, i'm still experiencing from my newer recording, but it don't seems to loose so much.
For the rest of course the device need full recap, cleaning, lub, and cal.
As for the cart, new pad, lub, new pinch roller.
But today as there is some resurgence, most cart are fixed which is i think a very bad thing as price sky rocket!
However as i want to use as background new fresh home made tape, old pre-recorded tape....
In search of the most convenient analog background music support...
Ps: @
tourmax stay in live forever why need people like you!
