Initially, I was thinking along the same lines. It would be relatively easy to just add a low pass filter with an inductor and cap having the same values as the high pass filter (1.0mH, 15uF). In fact that's one of the options an online calculator gave me, its called Chebychev Q=1. The Radio Shack catalogs refer to the 2 tweeters as midrange/tweeters. This could be tested on 1 speaker with no investment. Take the cap and inductor from the high pass filter on one speaker and use it for the low pass filter on the other speaker.
I'm trying to find the frequency range of the 2510Aa online short of pulling the leads and running some tones on it. I found a thread that referenced the same Nova 7b woofers and tweeters being in the Optimus 1B. http://audiokarma.org/forums/index.php?threads/rs-nova-15-and-optimus-1b-new-scores.447950/page-3
The Optimus 1B is in the same year catalogs as the Nova 7B and were a little cheaper with a fabric grill and a slightly smaller cabinet. I thought I was on to something when I found this thread, but the gist of the conversation was in finding replacement tweeters for the 2 that were fried on the author's Optimus 1B's.
Not finding any mods for the Nova 7B I did a google 'Optimus 1B Crossover Modifications'
http://the-radioshack-forum.1496864...-Crossover-And-Driver-Upgrades-td6450816.html
Not much here, other than someone replaced the 15uF caps and got an improvement.
The thread says that the woofer range is 25-300 Hz, but that must be a typo, he probably meant 25-3,000Hz. Further down on page 3 of this thread it mentions the crossover to be around 1300Hz, and also mentions it being a Chebychev Q=1 crossover. So if these values are correct the overlap between the woofer and tweeters would be 1300 to 3000. When running test tones I believe I'm hearing a larger overlap on both ends.
On this thread: http://audiokarma.org/forums/index.php?threads/realistic-nova-7b-crossover.515971/ I read that these tweeters 0705Ae will go down to 350Hz. Would my hearing a broader overlap be an indication that my caps are bad and need replacement? I'm 100% sure that all my tweeters are working because I hear them clearly at 15,000Hz. (the more I read about these tweeters the more lucky I feel at finding a set with all the drivers working)
I have the same concern - if we put a low pass filter in at the same values, we cut the woofer back to around 1300Hz, and I suspect that the two mid/tweeters aren't going to make up for that loss. Going higher, up towards 2000Hz, on both high and low pass would give some protection to those vulnerable tweeters. Videolady mentioned that the 12" Nova 8b woofers showed very good performance up to 1600Hz, so what does that say for the 10" woofers in the Nova 7B? So maybe shoot for somewhere between 1600-2000Hz.
Based on the online calculators there's more than one way to get there: Butterworth, Bessel, Linkwitz-Riley, Chebychev Q=1. Which way to go? Having no knowledge of how the cabinet and driver parameters, driver spacing (those 2 tweeters), 'lobbing' effect (lobbing? what's that), etc play into the design it would just be trial and error for me, and that could get expensive and still not hit an optimum.
I own a very nice set of Nova 7b's then came across the 6b's. Like both but the 6b's ummm. May edge them out by a few hairs.
I'm not familiar with the 6B, but looking online it seems that it is an 8 inch 2-way with only a single tweeter. A simpler speaker than the 7B with dual tweeters. The midrange might be better, but I bet it doesn't have the low end that the 7B (a 10 inch 2-way) would have.[/QUOTE
I had both paired with my Realistic STA 2200 receiver and that combo produced very nice low end to each model. The mid and tweets clarity on the 6b's stood out a few hairs above the 7b's. yes to my surprise the low end bass was not far behind compared to the larger 7b's with this particular receiver at low to moderate listening levels, The STA 2200 treat my Mach 2's 7b's & 6b's very well! They sound great all the way up the chain. With the surprise coming out of the smaller set.
In regards to the 2 midrange/tweeters on the Nova 7B. I recall skimming through the thread where videolady modded some Nova 8B's that have 2 midrange drivers and was looking to see if there is any insights that could apply to the Nova 7B. Maybe, Maybe not. The Nova 8B has two identical midrange drivers, 4 ohm each, wired in series giving an 8 ohm midrange. The Nova 7B has the 2 identical 16 ohm mid/tweeters but wired in parallel yielding 8 ohms.
Videolady made it a point in at least 2 of her replies to make sure the Mids and the tweeter had their polarity reversed or wired out of phase from the woofer. It even shows that in a wiring diagram she posted. Looking for an explanation of why; that thread is too long to read through again, but would the reason for putting the mids and tweeters out of phase have something to do with the lobbing? That comment about reversing the polarity stuck in my head as I always make sure that my speakers are connected to the amp in phase.
I just pulled a woofer from one of my 7B to verify the capacitor value. (15uF, 50v - yes) and to see if there are those plastic 'cups' over the backs of the tweeters (yes). I should have also looked at how the tweeters are connected, but it's buttoned back up now. I don't think they are wired out of phase based on the schematic you posted from 'stuart padeso'. I probably should have given that switch a cleaning while I was in there also. But I'll be back in.
I think I'm going to bale out on trying to modify the cross over. I've pretty much decided to just replace the caps, and seal things up. I know my limitations, and coming up with a new crossover design is beyond mine.
I do have a comment after looking under the hood. Nice build quality.
Here are some specs I collected on the 7B. Not sure where they came from.
Woofer = 2510Aa 8 Ohms 25Hz - 3KHz Nominal - 25W Music 50W Max
Tweeter = 0705Ae 16 Ohms 350Hz - 18Khz Nominal 5W Music 10W Max
Also have another doc that shows the crossover at 2000Hz and Sensitivity = 87dB.
The source was Popular Electronics June 1978.
As for mods I replaced the caps and changed the binding posts. Gave the switch a good cleaning and added a dowel from front to rear for bracing.
View attachment 806150 View attachment 806154
TPettenati, thanks for posting those values. I think everything is probably accurate except the crossover frequency, as Tim D pointed out.
I had suspected that the efficiency was below 90 as I have to turn up the volume on my 7B to get to the same level as my CS-99A which are about 93dB.
But 87dB is lower than I was hoping for. I think though it is possible to calculate the efficiency of the tweeters from what we know.
If I understand correctly, the attenuating resistor(s) in the highpass section of a second order crossover are to bring the efficiency of the tweeter to match the woofer. (I hope that is correct)
A little complication here as there are 3 settings - Low, Normal, High. On the low setting there is a 6 ohm and 2 ohm resistor in series = 8 ohm. On the high setting both resistors are bypassed. On the normal setting the 2 ohm resistor is in. So would or should we assume that the 2 ohm resistor is used to match the efficiency of the tweeter to that of the woofer? And then is there a formula to calculate what the efficiency of the tweeter is, assuming that the woofer is 87dB?
What, if any improvement, can you tell us of, after changing the caps and adding the bracing?
But, I have to tell you and Tim D, that the most amazing revelation here is that you both have essentially the same avatar!!
One in a West Coast Modern Style and the other in an East Coast Classical Style.
Proof that Geniuses think alike.
