I installed a liquid cooling system I built on my 3D printer. It's similar in concept to the liquid cooling systems used on computers. I use a heated enclosure for my printer, and the temperatures are high enough it can affect the performance of the stepper motors on the printer. I saw a printer that I think it was NASA had set up and thought it was a good solution, although I seem to recall they used air cooling system.
I haven't used my printer much since I set this up probably 4 years ago. I don't have a controller on it yet where the pumps are turned on by temperature sensors, so for now it's just a manual switch for turning things on and off. I used very quiet fans and thus far the motors on the pumps are quiet too.
However, somewhere, somehow, the coolant level drops over time. I've searched several times to try to find a leak, but haven't found evidence of one.
I turned it on a few days ago and let it run after filling it up again. The volume is probably 300 ml lost over a matter of a few years. It ran for a day, mainly due to I forgot I turned it on until I walked past it and felt the air being blown through the heat exchanger. Checked and still don't see anything leaking. I used what I would imagine is quality coolant, quality fittings, hose and manifolds. And wow, I remember the fittings alone were expensive.
Dunno.
I'm just wasting time until the firewall upgrades I have to do in about an hour.
