AMPLIFIER #2 CONFIRMATION CHECKS
Amplifier #2 was originally checked to insure the integrity of its transformers, but has now been restored enough to really roust it out of its who-knows-how-long slumber. Like it's mate previously addressed, the second can cap was hopelessly beyond any attempt to reform it, displaying an incredibly high power factor. The blue caps installed from some previous restoration effort could still be reformed, but since they were being replaced anyway, I decided to go ahead with that part of the restoration and replace all the can caps before powering things up.
Those following along might remember that I noted early on how the new bias caps that had previously been partially installed were installed with their polarity reversed in both units. But because these caps were grounded at the power supply ground point, correcting that problem also meant diving into the intermixed ground issues between the power supply grounds and the audio grounds (OPT Common lead grounded at noisy power supply ground at power transformer mount terminal rather than at audio ground point), so opportunity was also taken to install the new ground system as well. Finally, since new power supply caps were installed, opportunity was also taken to go ahead an install the Screen Stability resistors to protect the output tubes from any potential arc events arising from installation of the new can caps.
To allow for a proper operational start up, two of the old/new bias caps were temporarily tacked in place (polarity correct!), and proper hardware was used to mount the component tag board in place. This unit also arrived here sans a fuse and fuse cap, so a specified 4A fuse was installed via a correct fuse cap for the fuse post installed (secured earlier). Other than the points mentioned however, this unit still retains the updated circuit as installed by Fairchild. Collectively then, this work has amplifier #2 currently looking like this in preparation for its wake-up call:
The amplifier came to life quite uneventfully, with all chassis controls easily adjusting the output tubes to to an optimum setting. As previously noted, the 6AB4 input tube provided for this amplifier also had notable heater/cathode leakage, which ruins the S/N ratio performance in this amplifier as well. This will be resolved with new 6AB4 tubes for both amplifiers. Otherwise, measured performance for response, transient response, power response, distortion, and the like all validate that the performance as originally measured on the first amplifier, is in fact an accurate sampling of the performance that the design as built and produced by Fairchild is capable of. To that point then, this 10 kHz square wave should look very familiar to those who remember what a square wave of the same frequency looked like as originally produced by the first amplifier:
So, the beat goes on. More updates as progress warrants.
Dave
Dave
