So when I look at your meter pic, I see -53.22 VDC. Great, now to make sense of that, I roll up to post 109 with the scat chunk in it and see that the rails should be ±52.5V. That seems much better than blown fuses!!
Hope you don't get any cramps from that.After a couple of days with family down in VA...Fingers crossed....
Doug it looks really good now. Like the HP 3466 meter.
two voltmeters is great when doing bias and offset on a unit. Hook em both up and dial it in instead of having to swap leads from one test point to another.My brain says I need two voltmeters for some stuff and I just go along with that and continuously troll eBay.
Well lookout for those Onkyos then. The TX-4500 has three tape loops and No aux input. Sure does fool the folks that have an aux and no place to plug it in.So, everything seems to be working well (except the broken tuner string).
It's dead quiet with an active, turned-down input.
You... you have to push the STEREO button in... to get stereo output? It seems like that's its function, but... that's weird, right? @jdurbin1 thats what the STEREO button does, right? If so, are we just hearing summed mono otherwise?
There is no... no AUX input. Two PHONO ins and two TAPE ins/outs (each with level control), but... no AUX?
Unfortunately, spools of Dacron will do hundreds of tuners/receivers and I don't see a reason to have one of every size available for the next job.
