Hope you'll publish a complete parts list when it's all finished.
Nice work! Are these "tower" resistors non-inductive?
Weird... I keep finding that responses I've posted in this thread disappear and show up as unfinished drafts - trying again on this one.
Hope you'll publish a complete parts list when it's all finished... not a lot of these that have been gone thru completely so the documentation is thin at best.
John
I think is better if you rotate the transistor 180 degree.
Why is that?
More contact area. I doubt it will make a meaningful difference but it might be technically better.
I misunderstood @paul_ral and thought he was suggesting the pinout difference could be solved by rotating the transistor's ECB around to BCE.
Me thinks that would end badly.
In case the heatsink is longer you can drill a hole and fix the transistor so as that heatsink lean on PCB
What happened to the OEM driver heat sinks that brace against the boards?
