Thanks, if I'm following correctly you found a bad small signal transistor did
that fix the distortion or is it still there?
Did they break on you while working on it?
That along with your first lifted trace.![]()
These are easy restring projects and the manual has a good drawing in it for reference. I built jigs for these and for the 3000-series tuners a long time ago (using intact original cords and steel brads as pins stuck into a thick piece of cardboard to create a dimensionally accurate template that locates the key parts) so I can do a new string on the jig and then install it and tie off the one end before cutting the excess.
John
