I finally got around to loading many photos from two HK330C recap/rebuild/restores to Google Drive here: https://drive.google.com/open?id=1BnK_k1osh5Qrh0_jvQ-hdS4oiHbICk57
*idle current adjust: Set function to "aux", volume all the way down, tone controls set at middle. Using DC voltmeter, measure across leads of R428, then set current to 10mV by turning VR402 pot, on other channel, measure across leads of R427 and obtain 10mV by turning VR401 pot.
This looks like the same procedure for the 430, but it mentions putting an 8 Ohm 50W resistor across the speaker terminals before you do. Is that necessary? And would that be something like this?
https://www.mouser.com/ProductDetail/Vishay-Dale/RH0508R000FE02?qs=sGAEpiMZZMtlubZbdhIBIOzZS54oCXX/1YZYSGnjjuk=
It's not necessary. Just keep a load on the speaker terminals by having your speaker wires hooked up as you normally would when listening to music. 8 ohm 50 watt resistors are an oddball size and almost impossible to find that large in a normal, axial design.This looks like the same procedure for the 430, but it mentions putting an 8 Ohm 50W resistor across the speaker terminals before you do. Is that necessary? And would that be something like this?
In our case, the matching compliments (for the EQ board) isn't critical, so I'd go with a KSC1845 to replace the 2SC1344 and with a KSA992 to replace the 2SA844.
I was reading about a restore on a 430 and they said something like:
replace preamp low signal transistors 2SC1344 with BC550C on preamp and phono
Does this part look right to replace the 2SC1344?
https://www.mouser.com/ProductDetail/512-BC550CBU
Ok, so let's use the datasheets to see how well the BC550 would do in a spec-to-spec comparison:
2SC1344 Hitachi
Application: Low frequency low noise amplifier
Silicon: NPN
Package: TO-92
Pinout: ECB
Vcbo: 30V
Vceo: 30V
Vebo: 5V
Ic: 100 mA
Pc: 200 mW
hfe: 250-1200
fT: 230 MHz
nf: 1-8 dB
BC550
Application: switching and amplifier, low noise
Package: TO-92
Pinout: CBE
Vcbo: 50V
Vceo: 45V
Vebo: 5V
Ic: 100 mA
Pc: 500 mW
hfe: 110-800
fT: 300 MHz
nf: 1.2-4 dB
They are both NPN and TO-92, so they'll do the same kind of work and fit in the same kind of space.
The voltage-handling specs of the BC550 (Vcbo, Vceo, and Vebo) exceed those of the 2SC1344, so the BC550 will operate in the same place in a circuit.
Both devices can handle the same amount of current Ic and the BC550 can dissipate more heat, so it's a good candidate so far.
The gain of the BC550, depending on the device available from your source, should be in the ballpark of the 2SC1344, and we know they both perform in the audio frequency range, so they'll do roughly the same job.
The point at which they stop amplifying, the fT, is relatively close. So, they'll both amplify the audio signal and both are subject to unintentionally amplifying stray RF frequencies, so there is the same danger of oscillation or motor-boating or overheating with the BC550 as there is with the 2SC1344.
The noise nf that the BC550 adds to the signal is less than that which the 2SC1344 adds, so the BC550 is better for audio work.
The only issue I can see is the pinout. Because your original part is ECB and the BC5nn series is all CBE, you can't just rotate the device 180 degrees when installing. You'd have to twist the leads and therefore insulate them against shorting against each other. Totally do-able, I've had to do this kind of thing and been OK, just I wouldn't recommend it if you had easy access to a device with compatible specs and a ECB or BCE pinout (so you wouldn't have to twist the leads).
So, BC550 can perform fine as a replacement, better in an important area (noise), but the pinout difference makes it a less-than-optimal choice.
Just my hobbyist $0.02 opinion.
Good luck! Let us know what you do and how it turns out!
I had ordered those because they seemed close and I was putting in an order of caps, I'll see if i feel comfortable trying them out and if so I'll post some pics.
If not I'll order KSC1845 to replace the 2SC1344 and with a KSA992 to replace the 2SA844.
This would be a great replacement, but short pins might be a little tough depending on the lead spacing...
https://www.mouser.com/ProductDetail/WIMA/MKS2C034701C00JO00?qs=sGAEpiMZZMv1cc3ydrPrF7l45uRd9dVhXDUZ%2bDt6lMQ=
Or this with longer legs which are easier to make fit.
https://www.mouser.com/ProductDetail/KEMET/R82DC3470DQ60J?qs=sGAEpiMZZMv1cc3ydrPrF512ADDNLQZJtmppGuXf8zI=
Very good! ThanksThe key to getting long leads on WIMA MKP, MKS, FKP or FKS series caps is to order the cut tape or reel packaging. If you don't order this way, you'll get short 2mm to 5mm leads which make matching the original holes in the PCB difficult.
An example of bulk or ammo pack versus cut tape or reel:
Has anyone replaced the bias potentiometers, VR401 and VR402? I can't get it narrowed down.
Only specs I can find are:
HK Part No 23531300
1K Ohm, Variable
I think it's on this page:
https://www.mouser.com/Bourns/Passi...e/_/N-blayd?P=1yzmq8cZ1z0zlsdZ1y97o9lZ1yzuvtw
Thank you again Doug!! You've been an incredible help. I was also checking out your Noisy Transistors You Should Replace list and ordered 100 of the KSC1845 for $8 that will work for 2 sets of transistors. Really appreciate all the great advice.
Also found a transistor tester for $15 on amazon, looks like it will work fine for at least matching relative values on the transistors.
