Thanks Ray.Brought back as a public service announcement. That tweeter (Tang Band 28-847SE) is on sale at Parts Express for $12 each. link
That's a heckuva price!
I'll repost it in the Presidian thread.... :yes:
I saw that you had actively xovered a pair at 2K and IIRC Skywave-rider posted an RTA that was pretty flat, but I don't remember if Skywave-rider was using a crossover or RTA'd the drivers separately.
Edit: I found the data I was looking for:
http://www.audiokarma.org/forums/showpost.php?p=2345770&postcount=3140
If you research Jack's development of the E'Wave crossover, you'll find that the electrical highpass is much higher, up around 3.5 kHz; that's part of the HF compensation, as these drivers have excess response in the region of 2 kHz that must be corrected. Whether you do it entirely within the HF comp filter, or make that less of a task in combination with the highpass is inconsequencial.
Indeed, E'Wave is not "textbook," but this approach goes way back to the earliest days when Altec (and others) first determined that the excessively forward upper midrange produced by compression drivers was undesirable. It took another 10 years to recognize that HF comp could be used to extend the VHF of drivers capable of delivering it, once the prevailing supposition that response above 10 kHz was unnecessary was disproven.... :yes:
I don't remember if I ran the driver for raw response. But I do remember posting RTA using the ewave crossover. To get flattest response, I moved the mouth of the waveguide 1/2" back from the front of the baffle. It will probably be different on your setup.
I also posted RTA of this driver on different waveguides, so check out the applicable post.
---snip---116H and 116A show up frequently on eBay for cheap, just needing refoam, typically. The T/S parameters are the same. "A" is for alnico, in this instance. "H" distortion is lower.
