sxty8goats
I don't think I've logged in in 2 or 3 years. Thanks to everyone still building this. Makes me happy as heck to see them.
I saw one on Reddit the other day. It is kind of like seeing a photo of your kid in the news paper. So cool.
Okay, throwing my bin into the ring here with a build based off Dio's. I'll be selling vinyl records at my music shop in MA and this is the first display!I'm back with my latest build!
This one is solid oak stained with medium walnut danish oil and coated with satin polyurethane. Quite pleased with the end result: grainy and shiny!
I'd estimate the capacity at 500 records.
more pics:
Here's the blueprint:
It's a little shop in Framingham called Centre Music House. We mostly teach lessons and sell/rent/repair instruments. Recently came into a few collections though and decided to start selling in the shop.Where in Massachusetts will be or is your shop located?
Love the denim blue stain.Sorry. I just saw this request. I hope this helps. Attached are photos. Not quite finished yet. They will probably be better than how I can explain. We really just winged it. Next time, I would add 1-2 inches in width to accommodate for the sliders and use the dividers. We simply built a tray using the 3rd face piece for the front, the 3/4 birch plywood which would have been the bottom and 1/2 inch birch plywood for the back. 3" angle brackets to stabilize the back and 3 inch wide angle brackets for the front creating a tray. For the base of the cabinet, I used 3/4 inch plywood and mounted the entire cabinet in it so I could mount the wheels: Amazon https://www.amazon.com/dp/B09V5P2SSY?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 I used sliders also from Amazon https://www.amazon.com/dp/B0DJNR4S1V?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I’m definitely going to be making practice cuts beforehand next time. Some of mine were a little wonky with the skill saw. Glued and screwed everything together and used wood filler to hide the screw heads. Stained with cinnamon toast stain. Then two layers of polyurethane. Added some casters as well. Thinking about getting a magnetic rechargeable light for the bottom shelf.I finally did it!
I bought a couple of the about 8" long flat magnetic rechargeable magnetic LED lights with a motion sensor. They work great, and the batteries last a good long time between charging.I’m definitely going to be making practice cuts beforehand next time. Some of mine were a little wonky with the skill saw. Glued and screwed everything together and used wood filler to hide the screw heads. Stained with cinnamon toast stain. Then two layers of polyurethane. Added some casters as well. Thinking about getting a magnetic rechargeable light for the bottom shelf.
Looks great!Here are my three. I used a black stain and iron-on veneer strips on any of the exposed plywood edges. I use LED strip lights to illuminate the bottom shelves.
Thank you. Im building a fourth soon. I bought a piece of plywood last weekend. To anyone else considering building one, I have some suggestions. I have always used sanded, red oak plywood. It’s about 80 or 90 bucks for a sheet, but it is cabinet/project grade plywood as opposed to a $30 sheet intended for a subfloor or roof deck. I always cover the edges with 3/4 inch veneer iron on strips. It prevents splinters and makes it look like nice. I use a Kregs pocket hole jig and screws to attach everything. Pocket hole jigs are very sturdy and your screws are then covered with plugs to make them look better. Here are some links just to help you research a bit. Oh yeah, let the big home stores make your big cuts. Then if it’s screwed up it will be on them.Looks great!
Good advice man!Thank you. Im building a fourth soon. I bought a piece of plywood last weekend. To anyone else considering building one, I have some suggestions. I have always used sanded, red oak plywood. It’s about 80 or 90 bucks for a sheet, but it is cabinet/project grade plywood as opposed to a $30 sheet intended for a subfloor or roof deck. I always cover the edges with 3/4 inch veneer iron on strips. It prevents splinters and makes it look like nice. I use a Kregs pocket hole jig and screws to attach everything. Pocket hole jigs are very sturdy and your screws are then covered with plugs to make them look better. Here are some links just to help you research a bit. Oh yeah, let the big home stores make your big cuts. Then if it’s screwed up it will be on them.
https://www.lowes.com/pd/Top-Choice-3-4-in-HPVA-Red-Oak-Plywood-Application-as-4-x-8/1000177989
https://www.lowes.com/pd/Kreg-Kreg-Jig-320-Kreg-Pocket-Hole-Jig-320-Adjustable/1001107158
https://www.lowes.com/pd/Actual-0-75-in-x-6-in-x-25-ft-Natural-Wood-Red-Oak-Veneer-Edging/3179735
Those are really nice! Enjoy.Here are my three. I used a black stain and iron-on veneer strips on any of the exposed plywood edges. I use LED strip lights to illuminate the bottom shelves.
Edit-I forgot to mention that I also use the shelf liner as well. It’s probably not necessary, but I like to use it.
https://www.lowes.com/pd/Duck-Select-Grip-EasyLiner-20-in-x-15-ft-Black-Shelf-Liner/5014026439
